Old 03-27-2013, 01:21 AM
Default Re: CAT 963 Full Hydraulic Build
Not sure about Airtronics programming... your plus & minus settings, are they currently both at 100%?
Perhaps if changing to 80% on both sides, you'll get more valve movement with less pump rpm and maybe smoother control of cylinder travel for the bucket.
Old 03-27-2013, 04:25 AM
rockNmayhem's Avatar
Joe you nailed it. The settings were at 150% from the get go. I tinkered a little more with the programming last night and got it smoothed out much better. I have the lift at 100%, the lower set to 80% and the bucket curl is set to 75% with the dump being 60%. It is much smoother and still has plenty of power to handle 5lbs of lead strapped in the bucket with no real stalls.
I will get another video of it soon.
Tyler
~Tyler~
RockSolidCustoms
Old 12-17-2013, 12:43 AM
jack van's Avatar
jack van jack van is offline
For the hydrolic oil would either seeing machine oil work or the oil we use in air nailer both are fairly thin
Old 01-03-2014, 09:10 AM
ptebbe ptebbe is offline
Great work. Where do you purchase the items for the cylinders? (O-rings, seals, etc?)
thanks
Old 01-09-2014, 10:29 PM
Bg416 Bg416 is offline
Bg416 is on a distinguished road
Very nice work on the conversion. Thinking of making cylinders to sell?
