I've had satellite radio for yrs... the crap they call music today? I'd rather sit in silence.
Had to buy some new 6cell packs for the bd trl lately, so I stuck one in the ol' Mammoth for the 1st time in yrs and it works flawless as usual... just doesn't lift quite high enough is all, gotta jerk the last bit off the back.
![]() https://www.youtube.com/watch?v=ezTY...ature=youtu.be
Nice video Joe. That mammoth looks like it still runs well.
RIP FGD 12-19-11 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Just like the day as it was new, it's always been a strong runner... the only hiccups with this model are the suspension is a bit too stiff that axle articulation is poor with no load & the dump bed angle stops short a few degrees. This truck can move a lot dirt quickly.
Looking back to post #442, almost two yrs to the day since I last repaired this bucket cyl... I wonder why it won't hold?
![]() The ol' Mammoth works pretty good as a workbench. ![]() ![]() ![]() Just giving the cyl a coat of paint, I'll go brush the other half after this post. ![]() ![]() If it weren't for the leak, I probably would have been taken it apart soon anyway b/c the bolt that holds the piston to the rod was a few threads loose. ![]() ![]()
Hi Joe,
why don't you use any loctite on the piston screw? Ort you did and it came off? Markus |
Sorry to hear that the cylinder sprung a leak. The paint looks really good!
I believe I did (blue) locktite it Markus... although upon assembly I discovered the internal threads needed a tap run through it & the 5mm bolt had to be replaced. I suppose the 35bar is not only pushing the limits of the hose & soldered joints, but the threaded parts too.
![]() It's ModelMaster's black chrome, matches up well with the matt black JD paint I used. It brushes on streak free. ![]()
one day ill have a real mammoth. I have the cheap toy version of it. one just went on evil bay for 560 bucks.
Rc's are like pringles. You can't have just one!! my YouTube is - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Subscribe!! My Facebook - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Hey Joe,
I came across this article on Facebook the other day and immediately thought of you. #7 is amazing and #2 is completely unbelievable both in scope and detail. Maybe one day your underground complex will rival these. http://www.cracked.com/article_19421...in-secret.html |
Have you been running 35bars Joe??
I think it's hard to keep it from dragging itself at 22—25 bar! ![]() |
Deja Vu FB! I've seen that before, but don't remember how I got there.
![]() ![]() I thought I had it set at 30bar Kalle, but I noticed here lately that the gauge is reading 35bar. ![]() ![]() When I 1st started learning with the rc excavator more than a decade ago, an ol' pro come to see my hobby & within a minute of me showing him the model's ability, he said "you can quickly tell who's good & who's not by how much the tracks move up & down while they're digging".... that's something I took to heart from then on. In the vids of your's I see, you spend a lot of time sitting on rocks... where as I am flat footed on clay & the tracks will grip much better. ![]()
Did you ever finish the pup trailer for the green globeliner?
Hey Joe, I recruited a new member today. I'm at ConExpo, the Gates hose booth has 2 Vario hoes, the keeper of the models is interested in learning more about the machines!
I told "we" the forum would be glad to help out! Cheers, Neil. |
Have fun at ConExpo! Would be nice to be there by myself...
Put it on your "bucket" list! Been to every show since 1987.
Cheers, Neil. |
Good work Neil.
![]() Somebody from Vegas joined yesterday by the name of Kpro. We'll do what we can to help out. ![]()
I tried to work at the interior of my workshop the last couple wks of warmer weather, but my lower back just won't let me do that kind of heavy work anymore, so I got builder crew to do it this week, 3 guys did it inside of 2 days.
front entry – room is 24 x 30 sq feet. I have a 12’ width roll up door directly left of picture. I do my cutting, grinding, welding in this room. ![]() middle room – 18 x 30 sq feet. There will be a semi circle of sit down workbenches to the left of pic, going around from one door to the other door on other side of room. To the right of pic will be where my manual lathe & mill sits. The room has a closed in roof so it can be heated warmer than rest of building, I can work in a T shirt. Lots of room for new projects & old projects & space to make quick repairs to get equip back in the field asap. ![]() back room – 18 x 30 sq feet. Dirt floor, a place to mess around & test out new equip, painting parts, ect. The 850 will come out here after seeding to move piles of dirt around wall edges to seal up building from outside weather. ![]() back room – I will cut a door opening here to access lean-to structure. Lean-to will be 13 x 40 area, which will give me access to my house via a tunnel. ![]() this pic shows where the lean-to structure to be built this summer, but 1st I need to pour concrete slab in corner of house, northward 15 feet (camera currently pointing south), then lean-to will be placed one foot over north edge of concrete. Then the Lil Giants Constr Co will dig a 15’ x 4’ x 7’ tunnel under the concrete slab over the next few yrs. Approx 15.5 cu yds + additional yardage for elevated ramp to rise to ground level at approx. 12° incline. ![]() In a wk or 2, hopefully it's above 10C, I primer & paint the walls a bright white. Then the electrician will do his thing while I'm planting my crops in May... and sometime this summer I set up shop & start using it! Boy oh Boy do I have a lot of ideas & projects that have stacked up over the last couple of yrs. ![]()
Oh Lord the possibilities!! Train layout, shop, crawler course, road course, off road track, construction site......Geez
That's a dream come true!! In a few years I will be relocating to a house with detached garage, often thought about a tunnel from basement to garge, so me and the animals can come n go as we like. Keep us posted on the progress of the new shop. I always like to see where others do their works.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
