Old 05-06-2015, 05:23 PM
Default Re: 3D Printed D10T Build
Originally Posted by JDH429 View Post
Thank you, and sorry about that I never mentioned anything about that, or showed that the Servonaut SMT I'm using for sound is tucked up under the 2 Sabertooth 2x12 motor controllers. I printed a little organizer for the electronics to mount to, to keep things neat and the sound module can't be seen in the pics.
The sound isn't bad, actually sounds good in person due to the larger speaker and speakerbox I'm using. I had this SMT laying around, I'm curious to know what the new sounds on the new Servonaut modules sound like.. May have to place and order cause this SMT was actually supposed to be for my excavator.
Jason, I've haven't had experience with the sabertooth motor controllers yet but have a conversion on the books for one, why did you use 2? I thought that the 2x12 operated 2 motors? Sorry if I missed this somewhere.
Old 05-07-2015, 08:16 AM
JDH429's Avatar
JDH429 JDH429 is offline
Originally Posted by JAMMER View Post
Jason that looks real good. Ed
Thanks Ed
Originally Posted by Azonic View Post
Wow, very nice looking!
Thank you!
Originally Posted by rc_farmer View Post
Jingle bells, Jingle bells......., very nice build and extraordinary talent!
Thank you!
I used the second controller to operate the 12 volt linear actuators on the blade. These controllers are great, and will def use them again for my next project.
Jason
Old 05-07-2015, 08:42 AM
chris deacon's Avatar
Wow looks fantastic.. Some great skills you got there sir..
Old 05-07-2015, 10:14 AM
JDH429's Avatar
Thank you Chris! And also for the nomination on Build Of The Month!
Jason
Old 05-07-2015, 12:04 PM
Bo Wallen's Avatar
Thumbs up Re: 3D Printed D10T Build
Jason.
You just got 3D Printing to a whole new level..... extraordinary talented build and execution. Congratulation.
Bo
"Originally Posted by TRUCKMAKER View Post
I used the second controller to operate the 12 volt linear actuators on the blade. These controllers are great, and will def use them again for my next project."
Now it makes sense, driving the actuators separately to get your blade tilt
Old 05-07-2015, 01:56 PM
You figured out my secret!lol Doing it this way works awesome. Add another actuator to the C frame and you get the tip function. It all works very well and is quite easy so long as you have everything pivot and only anchor the blade on one side. I'm not sure if Jason is running his this way or not though? Are you Jason?
Reg
Old 05-07-2015, 02:51 PM
JDH429's Avatar
Originally Posted by Bo Wallen View Post
Jason.
Bo
Thanks Bo! The printer did most of the work
Yes, Im just using the actuators for blade up n down, and have both actuators tied together so the blade does not tilt left or right yet. I wanted to prove everything else out before getting tricky, but after running the dozer that function would be useful so will be working on that in the future.
Reg
Reg, yes your secret is out as i am doing exactly that. And yes the blade uses a draglink which is mounted on one side of the front of the dozer chassis. I should have moved that point as far to the edge of the chassis as the radius of that drag link would be larger and on full lift and drop of the blade, the blade shifts in towards the tracks as it follows the radius of the drag link. No rubbing, but ive made a note about that for next time.
Jason
Old 05-07-2015, 03:44 PM
Haha, not much of a secret! My first try at making the blade tilt didn't go great because I was using two actuators to "tip" the blade and that caused binding when "tilting". When I built the second conversion I didn't use any for tip but had learned from the first that one side of the blade must anchored to the C frame and the other side must "float". If both sides are held tight it will twist the $h!t out of everything and you won't get much tilt on the blade. I also switched from rubber bushings to spherical bushings where the C frame mounts to the track frames. This made a big difference as well as there is no resistance at all against twist. I went back and redid my own conversion and the blade tilt and tip works great now. Lot's of trial and error but we eventually get this stuff working sweet!
Old 05-07-2015, 07:39 PM
JDH429's Avatar
Wow, good info there. Thanks for sharing that. Yes, Test n tune is the name of the game here. Thanks for following the build and your help Reg.
Jason
Old 05-07-2015, 10:01 PM
Haha, yes lots of trial and mostly error. I usually get things figured out but sometimes the learning curve is steep. Happy to help any way I can....
Old 05-07-2015, 11:26 PM
Trucker_Jo's Avatar
Beautiful finished build there sir!
Jarrett
Old 05-07-2015, 11:39 PM
Wiskybilt Wiskybilt is offline
Wiskybilt is on a distinguished road
Can you add sand in the honeycomb for weight?
Old 05-11-2015, 10:09 AM
JDH429's Avatar
Thank you
Sure, I dont see why not.
Jason
Old 05-12-2015, 05:07 PM
JDH429's Avatar
http://3dprint.com/64122/3d-printed-caterpillar-dozer/
Dozer featured in 3DPrint.com article.
Jason
Old 05-12-2015, 07:11 PM
RobotArms24 RobotArms24 is offline
RobotArms24 is on a distinguished road
Would it be more expensive to print something like this in color? It would hide wear and tear better wouldn't it?
This project is fantastic btw, I hope to see more builds from you done like this. The article mentions casting wheels in a 3d printed mold, sounds awesome.
Old 05-12-2015, 09:01 PM
JDH429's Avatar
Thank you, believe me if they had a cat yellow filament I would be all over that. My next project is going to be a Euclid dump truck. They were like a lime/neon green and I happened to order filament close to that, so there will be less painting thankfully. On the other hand I did go with the grey so the wear was more noticeable on the dozer tracks and uc parts, I like it kinda.
Jason
Old 05-13-2015, 06:56 AM
D8R D8R is offline
Very interesting build (and technic with printer). Would love to learn more about using printing. A lot of details could be made this way!
Can't wait to see your next model, especially how to make those tires!
Old 05-17-2015, 12:30 PM
JDH429's Avatar
Hired some help
Have a matched set now that some detail has been done on my Vario build.
Jason
Old 05-17-2015, 01:16 PM
Your killing me Jason!
What a sweet looking combo I'm in love!
