Go Back   RC Truck and Construction > RC Truck's Ag and Industrial Equipment and Buildings > Construction Equipment > Construction News
Construction News New kits & accessories offered in the world wide marketplace
Old 12-22-2016, 03:52 PM
Default Re: New Eagle Mach Excavator 1/14
Originally Posted by egronvold View Post
It'a a huge difference in weight, the RC4WD weighs around 33 kilos!
So the majority of the model is now steel?
Old 12-22-2016, 06:06 PM
Not sure, but it's very heavy. I think the counterweight alone is close to the Stahl. My friend says it's very nice to use.
Old 12-29-2016, 04:59 AM
Northern Farmer's Avatar
Thumbs up Re: New Eagle Mach Excavator 1/14
Installed lights on a friends 360. Took the opportunity to take some pictures of the inside of the excavator, and some pictures to compare the size to my Stahl:
Thanks for sharing some detailed pictures of Eagle's new excavator. The company definitely made improvements with this model!
Old 01-01-2017, 04:34 PM
fabi fabi is offline
fabi is on a distinguished road
https://www.youtube.com/watch?v=brW1pwY4oUo
Install transmitter
https://www.youtube.com/watch?v=pXODWKR7znc
https://www.youtube.com/watch?v=AHM7pcPTUtw
Old 01-20-2017, 12:34 AM
Lightbulb Re: New Eagle Mach Excavator 1/14
RC4WD now offering Volvo decals for the new excavator
http://store.rc4wd.com/Volvo-Decal-S...0L_p_5271.html
Old 02-05-2017, 07:04 AM
Eagle now selling a light kit for the excavator.
https://www.aliexpress.com/store/pro...612.0.0.ETmZfO
Old 03-11-2017, 02:33 AM
Noticed CSMI is selling metal stone guard for the new excavator, looks good
http://www.csmi.com.au/index.php?rou...d=313&mfp=path[73]
Old 03-11-2017, 02:36 AM
Eagle also sells it
https://www.aliexpress.com/item/Mode...f1cea6d6&tpp=1
Old 03-26-2017, 06:45 PM
honda3 honda3 is offline
honda3 is on a distinguished road
What size are the clear hydraulic lines?
Old 03-27-2017, 08:21 PM
Pretty sure it's 4mm ID. The smaller hydraulic tubing is 2.5mm ID
http://store.rc4wd.com/4mm-Heavy-Dut...ng_p_3598.html
Specifications:
Alloy Zinc and Alloy Aluminum Casting (except Track and Hydraulic Pump)
Custom 8 Channel 2.4Ghz Radio
Preinstalled High Intensity Light Sockets (Wire and bulbs are not included)
Optimized Steel Hydraulic System
Scale Driving Figure Ready (Not included)
Steel Molded Tracks (50mm Width, 45 Grade Carbon Steel)
Efficient Undercarriage
Reliable Hydraulic Valve and Adjustable Pump
Heavy Duty Hoses (OD 4.5mm Nylon, ID 2.5mm)
Undercarriage May Rotate 360 Degrees (Endless)
Powder-coated in Yellow and Grey
Massive Brushless System (Including driving and turning)
Hydraulic System 60A Brushless ESC, Driving and Turning System 30A Brushless ESC
270Kv Brushless Monster Torque Motor, Shaft dia. 3.0mm
XT60 Power Plug Female
Run Time: 20 Minutes based on 4200mAh, 11.1V Battery
Steel Machined Oil Pump (60mm x 60mm x 93mm)
Digging Force: 15kg / 33lbs
Max Lifting Force: 70Kg / 154lbs
Driving Speed: 360 Meter per hour
Scale: 1:14
Length: 823mm / 32.4in
Width: 234mm / 9.21in
Height: 260mm / 10.2in
30 Days Limited Warranty
Operating Oil Pressure: 2.5Mpa
Inside Cab Length: 4.72in / 120mm
Inside Cab Width: 2.55in / 65mm
Inside Cab Height: 4.21in / 107mm
Deadweight: 26Kg / 57lbs
Old 03-27-2017, 09:38 PM
Thanks for the reply. I thought the hose their selling on RC4WD was the smaller black line running to the cylinders on the 360L. I couldn't find the clear lines for sale anywhere.
Old 03-27-2017, 10:57 PM
Yeah there's two sizes available on their site
4mm ID
2.5/ 2mm ID
http://store.rc4wd.com/2mm-Heavy-Dut...ng_p_3113.html
Old 03-27-2017, 11:13 PM
This is the smaller 2.5mm hydraulic line for comparison.
http://www.rcbrmin.com/index.php?mai...roducts_id=668
Old 03-28-2017, 07:12 AM
Thanks for the help man.
Old 04-13-2017, 03:17 PM
Does anyone know how i slow the pump speed down? what setting would that be on the radio?
Old 04-13-2017, 04:27 PM
EPA (end point adjustment), that might be listed as servo adjustment in your radio menu. What % is the motor running at now? Lower it too much & the motor will behave a bit erratic & heat up esc... for lower hyd speed movement you could lower the EPA on your valve chs so it takes more stick throw to open the valve or use 2s lipo, but a lower voltage will slow down your track speed too.
Old 04-13-2017, 04:34 PM
Try contacting Mario or DiggingwithMartin on youtube they will help you tune your machine right. Channel 5 is for the pump.
Old 04-13-2017, 09:35 PM
Yea on the fly sky TH9X that comes with the 4200XL it's in the endpoint adjustment. Ch 5
and on mine list as the first FLP channel. I have 026% on and of course 000% off.
Old 05-06-2017, 04:07 PM
look up to my video for setting , pump and sticks
Old 05-07-2017, 10:48 PM
Whats the best way to change the fluid in the 360l? I see there is a screw underneath the tank but how do you make sure you get it out of all the cylinders?
