Is the rear window machined from clear plastic?
"My son will have a chocolate milk" -J.P. Next East Coast Minitruckers Meet: Arioch |
It's a Knight hauler sun roof window. It's the right size for that use but I have some doubt about his light round form. But I think it will be good when glued...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Shiny parts are always a plus
Nice job so far Alfy |
How did you write in those clearance lights with the mfu? That's a lot of new shiny parts! Looking good
Hi my name is Aaron.... And i'm a truckaholic! |
Hi Dabears,
I don't remember exactly how it was connected. I tried to verify directly but it's not easy to see ![]() What I can say is that I used two connectors, so I connected seven leds on one and six on the other. Each ones are connected on the mfu with the roof light plug and the speed indicator plug. The speed indicator is desactivate by the control panel. The leds are connected in seried and parallels, but I can't remember exactly how and because the wires are almost all black, I have to dismantled tie-wraps (not a very clean installation...) to see the wiring way... If it's possible, it will be easier with my notes... ![]() Another thing I want to say is that I'm not sure about the safety of this wiring way, but it work well for me till now! The best way is to use a relay (I can give you a specific model) ans a separate battery... I'll try to give you more infos asap.
Ok cool don't worry about taking all apart... I can test the output voltage of the mfu to find my forward voltage and wire accordingly.. Thank you for the pics it does help alot!
Good... I'll probably take advantage of dismantling for taking notes on the wiring for myself if I don't find my own notes...
![]() I'll keep you inform anyway!
![]() Quote:
Very clean build !
Thanks Crewcab59!
Primer job is done on frame but my I broke my airbrush fitting while preparing things for painting red! ![]() ![]() Dabears, here's the way I think I configured my roof light (pdf joined). I can't be sure because I didn't note the polarity on wires and I'm not good enough with electronic to assure there's no other logical way... But it's the real wiring, with 8 leds on a connector and 5 on the other. Worked well for me till now, but not sure it doesn't have bad effects on circuitry or leds... Take care. A better way should be using a separate circuit with a servo switch like this one: http://www.robotmarketplace.com/products/0-PICOSW1.html. Hope it help! Gaetan
Looking awesome!! i do like how you mounted the fenders little different from the way i did, i like it though keep up the great work!!
Thanks dabears!
I think your way for mounting fenders seems better ![]() This forum is a wonderful place to learn! ![]()
I tried mine the way you did yours but my fenders have no play in them being hard plastic so with the suspension flex it put a lot of stress on the fenders or i would have done it the same as you. love your truck!! cant wait to see more
I see what you mean but there's another reason to prefer your way. Mines have some flex between them instead of yours and it's relatively ok about the stress between them, but after a while some misalignment appear. Not so bad and not so fast, but your way should eliminate that too. A change is really considered here... another item in the todo list
![]() PS Love your your globe & lowboy set too! ![]()
The new aluminum parts against the red really looks good.
![]() ![]() ![]() ![]() ![]() ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
Really looking great, love all the aluminum work.
![]() Quote:
![]() ![]() ![]() Quote:
![]() Thanks Kaf343! Gaetan PS. Hem... as always, sorry for my poor english knowledge, but this forum is a so great one...
i also can not waite till its back together! that window idea is cool. i like the whole set up alot with the trailers sweet truck!!
Grabbin gears and Rollin wheels ! LETS BLOW SMOKE!! Member of the Central Plains Mini Truckers,and a Minnesota road hammer. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Flat bedders do it with chains and straps,but now im yanking 53's To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Hi everyone!
Not a very productive summer on my truck ![]() ![]() I also worked on a new grill... ![]()
Looks Great! Love the changes!
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
