Old 04-16-2015, 07:12 PM
kaptain Jack's Avatar
Default Re: Liebherr 574
Makes perfect sense. Thank you.
Old 04-30-2015, 07:24 PM
gauthib12 gauthib12 is offline
gauthib12 is on a distinguished road
Hi Reg,
Are you able to let me know a bit more details on the motors you used? i.e rpm, torque, price, where did you get em? I was looking on the dx.com website..there are some good deals, but having a hard time to decide..I am assuming you have all 4 controlled by a single esc...any advice would be appreciated...thanks!
Blair
Old 04-30-2015, 10:32 PM
Hey Blair, I bought the motors off of eBay but I have also bought them off of Amazon and from Robot Shop. These last ones from eBay look exactly like the rest but have different motors(windings I guess). I forget the numbers off the top of my head but lets just say the normal motors I use are a something, something S and the new motors are just something, something. Needless to say they do not have the same power even though they look identical. They do however seem to have an adequate amount for this particular model though, I just would have liked more.lol Anyway, what I am running are 25mm diameter, 77rpm, 6 volt motors. I can dig up a link to the ones I purchased if you like. So many sellers have the same or nearly the same stuff for sale. I bought these last ones because they were under $10 a piece and had free shipping. I won't buy them again but they are doing the job. I also have the same type in my Bruder Mack but use 133rpm ratio. Hope this rambling helps...
Reg
Old 05-01-2015, 09:53 AM
Hey Reg, thanks for the info I seen allot of good deals too for under $10, just got to pick one! lol.
Cheers!
Old 02-13-2016, 05:36 PM
OK so this one is for you Mario! One hand crafted, TIG welded, stainless steel exhaust tip to replace the repulsive, ugly, plastic, Gonzo nosed factory piece on my loader.lol
Bo's size reference pic
After welding it up I turned down a piece of dowel to suit.
Then finally the new pipe attached
Old 02-13-2016, 05:48 PM
nice beaver
Old 02-13-2016, 06:13 PM
Bo Wallen's Avatar
Talking Re: Liebherr 574
nice beaver
Shine Beaver
Old 02-13-2016, 06:19 PM
You only made one?
Looks much, much better than the gonzo version.
Old 02-13-2016, 07:43 PM
Originally Posted by Supermario View Post
You only made one?
Is that a hint?
Old 02-13-2016, 09:08 PM
I was also playing with this afterwards... It has some bugs but they are only slightly annoying...
https://youtu.be/YGBbyPXwa_I
Old 02-13-2016, 10:38 PM
Reg, you need a diode in the lead of the beeper. To make it quieter, put a band aid over it!
Cheers!
Old 02-13-2016, 10:48 PM
Cheers!
I tried a diode on either end facing either way and it would either make it not work at all or do the same as in the video. I'm not sure what I was doing wrong? Maybe a different diode? It's gotta work somehow Neil!
Old 02-14-2016, 03:07 PM
https://youtu.be/ebd_ZFI8ats
Old 02-14-2016, 08:09 PM
Reg, I think you needed a higher voltage rating on the diode,
Here's a short page on them, http://www.ehow.com/how_7433946_choose-right-diode.html
Your new setup works great!
Cheers!
Old 05-01-2016, 12:42 AM
Cre8rc Cre8rc is offline
Cre8rc is on a distinguished road
Nice work on the Bruder, I am in the midst of ordering parts to convert mine. I like your idea for the motors because I too am somewhat of a hoarder of small items and have some old stainless steel solar light tubes.
My question to you is how did you fasten the motors in the tubes so they don't spin in the tubes under torque?
Old 05-01-2016, 11:13 AM
Thanks. The tubes are split to fit over the motors and I just used electrical tape the close it up tight. On the rollers I converted recently, I used the same setup but instead of tape I used some really heavy shrink tube. Either way seems to hold the motors fine with no slippage.
Old 05-02-2016, 10:11 PM
Perfect.. Thanks for the help.
Old 05-12-2016, 05:04 PM
Cat966c Cat966c is offline
If you don't mind me asking. What actuators are those? How do the esc's hook up to the actuators and motors, and also what controller/receiver/transmitter are you using?
Old 05-12-2016, 10:03 PM
Firgelli actuators. They are L12S 6V. 2-50mm and 1-30mm. Most guys use the L16 actuators because they are stronger. They are also a bit bigger on the motor end and 12V only which I didn't like. They hook up just like any brushed motor. I'm using a DX6i and an Orange RX receiver on this one. ESC's are the cheap ones from Hobbyking. They work perfect for under 9V and they are just over $10US.
Old 05-13-2016, 05:31 AM
jdwtrans jdwtrans is offline
jdwtrans is on a distinguished road
Hi, just wondered how you make the teeth for the bucket ?
