Old 11-09-2015, 04:49 PM
Bo Wallen's Avatar
Exclamation Re: Great Dane excavating co.
Hey Cooper !
This might avoid future BackPain Just train Mr Nutter to drive The RockBeast and the transportation is solved. Roll on roll off :https://www.youtube.com/watch?v=OPdCDj_RiKI
Old 11-09-2015, 04:55 PM
Good idea Bo, but mr nutters has moved onto another worksite, he now works for the forestry department.
Well I know I got the pigment right this time. And I mixed for 1 min, immediately poured and had the mold slightly unlevel, tapped mold, basically did everything I could to eliminate the air. Time will tell, about two hours and I get to see if hero or zero!!!
Old 11-09-2015, 06:32 PM
Bo Wallen's Avatar
Thumbs up Re: Great Dane excavating co.
Drumroll, Please !
Old 11-09-2015, 08:28 PM
Here ya go mark,Bo,, and some scale along the aeromax
Old 11-09-2015, 08:34 PM
Bo Wallen's Avatar
SCORE !!! You Sillycone Guru
Old 11-09-2015, 08:38 PM
the tire is as tall as the aeromaxxxxxx
epic build going on here!!
back to my little kat
Old 11-10-2015, 08:52 AM
Nice! They barely look like a permit load.
Old 11-09-2015, 08:47 PM
Mikem Mikem is offline
Impressive cooper . I think you'll be able to put all my trains in the box ! Mike
Old 11-09-2015, 08:50 PM
May Santa bring you a box full of hero cookies! That is awesome my friend!
Old 11-10-2015, 10:15 AM
They really turned out good. What durometer did you end up going with?
Old 11-10-2015, 12:37 PM
I made the first one a60, pretty firm, the second try is A40. I think the 40 will be better. Can squish the treads easy but I don't think the tire will roll or flex too much once on rim.
Old 11-10-2015, 03:51 PM
Tire looks good cooper!!
Old 11-10-2015, 04:30 PM
Thank you!! I found the sweet spot on this mold, I now have 4 nickel sized vent holes. And have the mold slightly unlevel. Before I mix the resin I degass the A side with dye. Introduced a few air bubbles and that side is the rather thick side. That pulls a lot of small bubbles suspended in it. Then mix slowly. The B side is pretty thin so when combined it is fairly thin. Slowly pouring and tapping and pushing on mold released most stuck air bubbles. I think the ruff side of the mold creates just enough surface tension for air to stay put. Guess it goes back to really spending time on the mold part, really making smooth. I just figured it's the backside and wouldn't show so I didn't spend much effort on that side. But the finished tires will be fine for me. Throw some mud on and it will look fine . I guess that's why I like my stuff scratched and dented, it hides a lot of the imperfections !! Lol!! Just waiting for some alum to show up and then start the smoke pouring from my ears! Tires are just a couple ounces under 4 pounds. And I think I got the pigment correct. 10 drops of black pigment each tire.
Old 11-10-2015, 05:24 PM
Huge run flats ? Mike
Old 11-11-2015, 10:26 AM
Tires look fantastic buddy... took me awhile to get caught up entirely on your thread, I was absent the last couple weeks of October.
Anyways, considering your motor options... I checked the motor output of the 4206, pulled the wheel off to get an accurate shaft rpm of 87 & my gizmo has a wheel adapter too, measuring surface wheel rpm 347. The 4206 has a 4 7/8" tire & the model moves along nearly at walking pace (I have a 36" inseam, I take big steps).
Old 11-13-2015, 10:19 PM
thanks joe, I still haven't decided what gearhead motors I'm going with..,, I'm waiting on some alum to show up and then ill figure out what motors will fit inside the axle housing. I may even take brian from exclusive rc advise and make printed parts once the motors are secured.
Old 11-14-2015, 02:16 AM
I noticed a few pages back you said got some .55hp motors, they have gearheads on them too?
I did the measuring of the 4206 to try to find out what might be a good speed for your trk with 8" tires & hopefully still have plenty of power to move 160lbs with just two motors... the math works out to something between 50-55rpm.
Ofcourse with your tools & talent you could also add an outboard planetary hub for more reduction from a faster smaller gearhead motor, pulling the guts out of a cordless drill.
Old 11-14-2015, 11:22 AM
Here are the motors I got , well in mail. They may have to me taken apart and incorporated into the axle housing for a more slim mount. Being square, and the outside of gearhead may be just a little bit big. Don't know exactly till I get to it.
http://www.robotmarketplace.com/products/0-PDX256.html
90 rpm at shaft, and the stated hp is .55. Hard to believe half horse at shaft. But 256 reduction, I might not want to get my fingers swisted up in it. !! And having a half inch shaft that is already tapped at end, keyed,, that makes a lot more options I have for adding a weight bearing shaft. Your posts a while back on the adt, with fumotec axles is what gave me the idea. So reciprocating the posts, thanks.
Old 11-17-2015, 12:55 PM
A start to the drive system.
Old 11-17-2015, 02:58 PM
those look huge or you have small hands
like mr.nutters
