Old 04-22-2011, 02:39 PM
steamer's Avatar
steamer steamer is offline
Default Re: Steamer
Finally got the reach finished with lift jack installed.
Also had a chance to get some outside shots of the FWD.
Thanks for looking.
Old 09-05-2011, 12:02 AM
Ken Orme Ken Orme is offline
Default Re: Steamer
Originally Posted by steamer View Post
You Bet. Greg and Lou were here this afternoon and we put 25 lb. on it and it lifted no problem. I'm not sure how much the dump box full of dirt or sand will be, but I think it would probably be less and handle it fine.
Dry sand is 100 lbs per cubic foot.
Old 09-05-2011, 04:17 PM
steamer's Avatar
Default Re: Steamer
Neil. I'd never seen anything like that either and it sure is a different arrangement.
Ken. You bet sand is a lot heavier than it looks. The FWD pulled itself and the loaded trailer but the tires are not aggressive enough for anything over 6% grade. Anyway here's a couple more pictures from the Show.
Reg's dozer and Euclid with the FWD behind.
Lou looking real casual with the 966 loading his ADT.
Just a general scene of the layout.
Thanks for looking.
Old 04-23-2011, 01:25 AM
RCLogger's Avatar
RCLogger RCLogger is offline
Default Re: Steamer
Nice work on the reach Rob, the FWD looks great. In think you are going to have to learn to run the hoe, as the bumbs who run it now will be alittle rough on your shinny rig... LOL
greg
Old 04-23-2011, 02:47 AM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Default Re: Steamer
Try this link.
See how the use Transfer Truck and Trailer.
TEXKEN
Paste link in WEB site(only), will take you to the site.
Look for the Contest on right.
http://www.youtube.com/user/zpetester
They turn off Truck leave in reverse and use starter to back truck when hooking trailer up.
Old 04-23-2011, 12:50 PM
steamer's Avatar
Default Re: Steamer
That's quite the video. Those guys make it look way to easy!! Mine is not quite a transfer but it kinda looks like one. Next time around I'll build one all the way, and go for the two trailer version. Thanks to Steve, I have the high lift tailgate figured out.
Old 04-27-2011, 11:01 PM
TheMachinist's Avatar
Default Re: Steamer
The reach looks really good. What are you using for heat when soldering?
Old 04-28-2011, 01:31 AM
steamer's Avatar
Default Re: Steamer
I just used a propane torch for it all. The tubing joints were all slip fit so I used resin core solder. As the pintle block had no attach points, just cut into the square tube, I silver soldered it for strength. Turned out to be quite strong but we'll see how strong it is, after first time I jack knife it.
Old 05-08-2011, 02:35 PM
steamer's Avatar
Default Re: Steamer
Time to update some pictures. got some of the box built out of styrene.
Also decided to build the tailgate hinge from styrene and it turned out quite strong.
Trailer in travel position.
Trailer in dump position.
FWD and trailer both with boxes up.
Thanks for looking
Old 05-08-2011, 04:53 PM
Default Re: Steamer
Wow that's really looking good.
Can't wait to see it in action.
Old 05-09-2011, 04:37 PM
Azorean Azorean is offline
Azorean is on a distinguished road
Default Re: Steamer
Very nice...
Looking great
Old 05-08-2011, 06:54 PM
Default Re: Steamer
Hey Rob, that's a new twist on semi dump trailer's! Different from the Clement Bridger, but very neat. That could be a new way to mess with the "DOT" LOL
Later, Neil#2 aka doodlebug.
Old 05-09-2011, 10:57 AM
steamer's Avatar
Default Re: Steamer
Thanks guys. Yes it's a little different for the transfer but it sure can lift a lot. Next time it'll be a full transfer setup.
Old 05-09-2011, 07:19 PM
JensR JensR is offline
Default Re: Steamer
Very cool mechanism, works a treat!
We don't have them over here.
Old 05-09-2011, 07:58 PM
Default Re: Steamer
Nice work Rob, that trailer mechanism is well done.
Old 05-10-2011, 11:22 PM
Jared Jared is offline
Default Re: Steamer
I like it!
Old 05-10-2011, 11:53 PM
steamer's Avatar
Default Re: Steamer
Thanks Guys for the support. I'm Working on the tail gate lock and I'll try to get pictures up in the morning.
Old 05-11-2011, 02:28 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Steamer
This is looking awesome Rob, I like the styrene work on the box.
Mike "DREAMWEAVER" Johnson
Old 05-29-2011, 01:25 AM
RCLogger's Avatar
Default Re: Steamer
Hey Rob,
Great fiberglass work on your new model, not sure how well it will go in the dirt though ! hahahah
greg
Old 05-29-2011, 01:59 AM
chaseracer's Avatar
Default Re: Steamer
awesome work Rob, trailer looks great.
