Old 04-06-2011, 09:44 PM
Oil Field Construction's Avatar
Oil Field Construction Oil Field Construction is offline
Oil Field Construction is on a distinguished road
Default Re: CAT 535C Grapple Skidder
Originally Posted by Snochaser View Post
I received a nice little box of goods in the mail the other day! Finally after 11 months. Time to dig in.
Ben
Ben, any new progress on the Skidder! Can't wait to see it in action.
Old 04-22-2011, 08:33 PM
Snochaser's Avatar
Yes, finally! A little at a time. Time has been rare for the hobby as of late, but I'm making a few progressive steps.
Thanks for checking.
Ben
Old 06-11-2011, 10:03 PM
Snochaser's Avatar
I'm slowly getting there...
Waiting for a little more hose and some additional time.
Will I have problems with the lines coming off if I don't use the sleeves on the ends?
Ben
Old 06-14-2011, 01:17 PM
rc_farmer's Avatar
Master Builder
Ben
Probably so, especially if the hose fits rather easily and the cylinder is under alot of pressure for an extended period of time. I don't like the big sleeves, so in certain places, i have used very small, black tie-raps and tucked the head underneath. Hope that helps.
Giving up is not an option!!!
Old 06-15-2011, 09:27 PM
dirtpusher9's Avatar
Moderator
Won't be long now. Ben I used the 2.5 mm hose and fittings and haven't had any trouble except when I didn't leave enough hyd. line. It needs to be square with the fitting. Looks good , ready to see it dragging a load of logs.
Old 06-17-2011, 10:29 PM
Snochaser's Avatar
Thanks for the input guys.
They do fit very tight on the barbs. Hope they don't come off, but any sign of it I'll try the zip ties 1st. I'm hoping to get it nearly completed this weekend.
Ben
Old 06-18-2011, 04:10 PM
rc_farmer's Avatar
Master Builder
Keep up the great work, can't wait to see it pulling some logs. Need to have a Swamp Logging contest 2 Indy....
Old 06-18-2011, 04:39 PM
looks great Ben I got the logging truck just about ready
Old 06-18-2011, 08:46 PM
Snochaser's Avatar
Ihbuilder, I'll be more than happy to drag some logs to you in Indy.
Old 06-18-2011, 08:47 PM
Snochaser's Avatar
I'm waiting on a return call from Ric to send me some 1/8" od tubing. That's my hold up at this time.
Old 07-03-2011, 08:32 AM
Snochaser's Avatar
It lives! Finally. I will post a video once my computer is up and running.
Old 07-04-2011, 08:10 PM
Snochaser's Avatar
I am pretty tickled with the performance for my first attempt at one of these models. Finally after 16 months I have found the time engineering and money to do this. The battery (12v pack from PMD) seems to die fairly quick from what I thought it would. I can't figure out why my speed control will radomly just go into full reverse or forward without warning (as you can see in the one of the videos when it starts to just back up at the end), if I mess with the dip switches it will go back to "normal". I hope in Indy I can get some hands on help from you guys to help me fine tune it. The bottle in the video is a 32oz. Gatorade bottle to show the strength. I think it does pretty well.
Video below
Old 07-04-2011, 10:26 PM
rc_farmer's Avatar
Master Builder
That is on-point Ben!
Old 07-05-2011, 10:33 AM
Ken Orme Ken Orme is offline
Ben;
I like your skidder. Very good.
What did you use to "weld" some of the aluminum parts together?
Old 07-05-2011, 02:19 PM
JensR JensR is offline
Very very nice!
About the ESC acting up: Do you use a "self-learning" ESC? If those switch off, due to an intermittent connection, over-current or over-heating, they will come back after a short while and take whatever position the stick is at as their new neutral. I therefore strongly advise against using them, but I know some people prefer them.
Not sure what your problem really is, just had this idea...
Cheers
Jens
Old 07-05-2011, 07:35 PM
mog mog is offline
look very good seeing your working so well make me think i should take my skidder down off the shelf and finsh the grapple and the blade up.
Old 07-05-2011, 08:26 PM
Snochaser-your model looks great and seems to perform really well! Nice job!
Old 07-06-2011, 12:25 PM
Snochaser's Avatar
Thanks guys. I will try to post a few more videos tomorrow if I get the time. Gotta find some "logs".
Old 07-07-2011, 01:32 AM
No shortage of power, I can see that! My favorite thing about this build is that it didn't require a whole bunch of expensive metal working machines to complete, and yet it's looks good and runs good too.
Old 07-07-2011, 06:40 PM
rc_farmer's Avatar
Master Builder
Ben, are you using the DE Sabertooth 2x12 RC ESC?
