Old 01-23-2011, 09:20 PM
Default Re: 2 IH 433 payscrapers (ps433-2 moves)
Looks good Steve your getting there slowly but your getting there.
Old 01-23-2011, 09:40 PM
Snochaser's Avatar
Nice Steve, you'll be able to run shale through that with the weight and strength.
Old 01-23-2011, 10:05 PM
I like Steve - plenty of power and not too fast so it makes nice clean cuts
What's left to do?
Old 01-27-2011, 04:14 PM
Originally Posted by SmallHaul View Post
Nice power Steve!
That machine is sooo heavy it should shave earth easily.
What's left to do?
thanks guys yea she'll load well can push me across the floor Chris ,I got a lot more to do but it went back on the shelf again like all my stuff I got to much to do and deal with right now and get everyone's stuff made . the list keeps getting longer
IHSteve
Old 01-28-2011, 02:03 AM
rc_farmer's Avatar
Master Builder
Steve, you are doing a great job, can't wait to see you cut some mud!
Giving up is not an option!!!
Old 02-08-2011, 09:02 PM
td9clyde td9clyde is offline
Dozer Builder
Steve ........hows things going? haven't seen any update pics lately hows your 40 comming along?
Old 02-08-2011, 10:28 PM
yea I can't either
back on the shelf for now Henry , same with the 40 . I kinda got this new toy and got to get it making some dough and right now It's got me a little trying to figure why it will not come off em stop error 04 it seems 2 servo amps where replaced within months of each other but 1 does not appear to have been replaced . Also trying to figure out how a running machine before I bought it ( saw a vid of it running maybe this 1 or the 1 they still use ) and not when I set it up 1 referb amp $1000.00 for glentek and $350.00 for a rebuilt SD1525-16 which I think is OEM not only that , I got orders and trying to get some of these trls wrapped up and out of the shop till I decide to light them up .
Steve
Old 02-09-2011, 11:39 AM
well lucky for me there's nothing wrong with the mill now I just need phase conversion for the spindle turns out I forgot a wire when separating the control from the power switch for the whole machine .
IHSteve
Old 02-26-2011, 06:46 PM
I'm wrapping up my highway truck building and coming back to my construction equip. . after sometime on pondering this build ,I decided to change the motors ( to slow ) When I got the motors , I over looked the output speed of the motor being reduced by the differentials . since I'm taking the motor I was going to use in the TD40B I need replacements these are the right size to go side by side and got plenty of room to play with gears ratios and multi-speed trans. Also I'm going to bite the bullet and buy the hydros .
Steve
Old 12-18-2011, 10:43 PM
I put this back on the bench after I saw Steve do a motor swap on his tunarocker I had 2 motor siting around with double the speed as the original , so did a motor swap and Stevie is a happy camper I was going to try to get it going for cabin fever and supprise everyone but As always not enough time to do both pan and mack we'll see how it goes though
Old 12-24-2012, 04:09 PM
Dozer Builder
i seen those at tri state tractor show lol nice try Steve can't pull a fast one that easy nice models though
Old 12-08-2013, 10:04 PM
now I know what was under all that dust in the corner
I started on remaking the gooseneck . The block in the vise is 5"x3.5" x 24" still need to finish the top and flip and cut the underside out .
till next time
Old 12-08-2013, 10:31 PM
I was getting worried about you! I thought you were too busy making money and forgot that you have to build yourself some stuff to keep it fun. All joking aside, I'm happy to see you milling some parts again for one of your many projects! It's not the same around here when we don't have your "updates" to look at.
Snochaser's Avatar
Keep the chips flyin'. Pokie!! Looks good.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 12-09-2013, 09:18 PM
making $$ problem is I enjoy makin stuff that I get to many ideas goin at once . I know I can make this werk just need to keep at er .
thanks ben waitin for more brass to come in
Old 12-09-2013, 09:33 PM
More setup pics, finished part - the welding , and comparison pics
first is setup to face the outside . I don't have a sine plate so a lil improvising the facing was done manually no need to waist time programing that I did a lot of setups do to what I had in long (lack of ) length end mills
cut out last op
what I couldn't do with the 1st neck
1:25
comparisons
cpt jack running the 1:25
till next time
Old 12-09-2013, 09:43 PM
I did make the new wheels for it over a year ago (dust )just never posted them . The caps are programed just need to put a plate in the vise and cut .
Old 12-10-2013, 10:39 AM
Stefan Stefan is offline
Great work!
Old 12-10-2013, 11:00 AM
Glad to see your back at this one!!! Cant wait to see more shavings flyin
Old 12-10-2013, 11:55 AM
I love watching parts being machined. The new neck looks great, and I like those models too. First Gear replicas?
