Old 12-08-2014, 09:36 PM
Default Re: S&M construction open for bizz nizz!
Originally Posted by RCP57 View Post
Will you be able to make two? Innie and an outtie?
I was hoping to get a Innie but the valve stem is smack dab in the center line going to try and remove the stem and salvage that band of rubber.
Originally Posted by Mikem View Post
How are u going to cut it . How about inflating it and marking it out . Just a thought . Mike
The way I see it Mike, if I can't cut a straight line, maybe the fact I'm dealing with a circle will work to my benefit !
I thought about inflating , laying on the floor and make a jig for a marker to roll along the floor around the circumference but.... Too complex! Keep it simple right?
As Joe mentioned, there are clear mold lines in the rubber I can follow. First cut will be extra wide and outside those lines, more belt than I need. Once I get rid of the excess and the belt is easier to work with, I can map out my final cut lines.
That's what I'm thinking anyway. Definitely open to ideas and suggestions for making a nice simple , straight cut.
Old 12-08-2014, 09:40 PM
Cut it when it's inflated, will be nice and solid, lol!!!!
Na , make sure you keep posting on this progress, I'm learning!!
Old 12-08-2014, 09:55 PM
Who knows RW. My next post might be ...... " fresh ground rubber for sale"
I like the cut inflated idea but I don't think my air compressor has enough volume to keep up with my cutting
Old 12-08-2014, 09:59 PM
Lol!! Good one!! Stop over at Great Dane co., I might have a supersize for you if that rubber get a snag.
Old 12-09-2014, 07:40 PM
Small update on the conveyor build.
Just so we're clear, this is not scale or highly detailed but all about functionality. Translation....it ain't pretty and I don't care !
Working with basic tools and materials makes people do funny things like a trip to the arts and crafts store for 7 bucks worth of wooden beads
I figure a quick easy way to support and help create a dished belt
Once I get the belt cut I can figure where to mount these but I'm sure you get the idea....
And the basic frame I started before getting the tire tube so I may have to redo with longer aluminum flat bar. 1/8X 1 X 4ft long as it stands...
Like I said, nothing fancy. This is the research and development version, see how it works. So far really cheap and really simple.
Old 12-09-2014, 07:58 PM
Bo Wallen's Avatar
I wonder if this could help a little ? It,s cheap http://www.globalindustrial.com/p/mo...B&gclsrc=aw.ds
Old 12-09-2014, 08:45 PM
Don't try to BS us! You had those beads already....I won't say what you were probably using them for.
Old 12-09-2014, 09:08 PM
awh you let the secret out Reg!
Now everyone knows I make custom wooden bead car seat covers in my spare time.
Old 12-09-2014, 09:14 PM
Thanks for the link Bo. I notice the minimum drum diameter they recommend is 3" and that's probably due to the staples that keep it together can't make a tight radius.And that's for a commercial use , for what I'm doing this might work? I might have to enquire further. Thanks again
Mario
Old 12-09-2014, 09:24 PM
woodhog's Avatar
woodhog woodhog is offline
Hey Mario, Izzy had a belt made for my belt trailer that is continuous and is vulcanized so it doesn't have a seam and its a real nice . Give him a holler it will work perfect and can be made any length
Woodhog
Old 12-09-2014, 09:27 PM
It was time to let the cat out of the bag my friend...
I like the bead idea and I hope it works out! Way more cost effective than machining rollers if you can get it to work!
Old 12-11-2014, 09:57 PM
Thanks for the info Chris . i haven't talked to Izzy since he built our tri axle end dump trailer. Only seems appropriate to ask him for help building something to load his trailer
In the meantime I got a chance to start cutting this tire tube. I cut the valve stem out and trimmed the stem layer down and now can use the inner circumference for a belt. It's a little shorter than 4ft but will work great to test things out.
First cut to make things easier to handle...
its 4" wide now as I followed the centreline visible mold lines. Final cut next I think will be 2 3/4.
As you can see by the smiley face strip you don't have to go very far off centreline and things get unusable.
Old 12-12-2014, 02:30 AM
Joe25's Avatar
Joe25 Joe25 is offline
Joe25 is on a distinguished road
Mario, just ran across this thought maybe they'd have somethin for ya,
http://www.mini-mover.com/conveyor-o.../belt-options/
Best of luck, shaker looks awesome btw...
Make peace or Die! 1st Bn 5th Marines
Old 12-12-2014, 03:01 AM
Joe25's Avatar
Default sorry for the double reply...
http://qcconveyors.com/conveyors/125...fications.html
Found this one on a separate page can custom order the belt...
Old 12-12-2014, 09:54 PM
Looks good Mario!! Man I miss working with wood!! A couple years ago, before I had any metal equipment , I built a springer tug. I got detailed with the superstructure. All wood and I thought that was unforgiving!! That tug is a good part of the reason I bought a mill/lathe combo!!! I really wish I could make hydraulics from wood!!! Good idea to build and learn, that what I need to start doing . Keep up the pics!! .
Old 12-12-2014, 09:56 PM
Oh and I was thing of some other use for the beads , not a curtain lol!!!!! I think they call them love beads ??
Yea this might get deleted
Old 12-12-2014, 09:58 PM
See Mario, I told you he was like us.....
Old 12-13-2014, 12:41 AM
Well, I did lots tonight and got nothing accomplished
Call it an evening of beads and rubber belt experiments. ....did I just say that?
Old 12-13-2014, 02:45 AM
jack van's Avatar
jack van jack van is offline
Talking Re: S&M construction open for bizz nizz!
i could use 1 for my king hauler and my excavator when i get that lol
Old 12-13-2014, 09:02 PM
So the test conveyor is coming along nice. original idea was a belt about 2.5" wide but quickly realized it's difficult to get a good curve or dish in the belt when it's so narrow. Didn't want to go too wide though and require more turning power and a stronger motor.
Long story short, new belt width is approx 3 3/4" and much easier to work with.
Here's a video of it running for the first time. Even without the rollers, the belt tracking is very decent already! I'm happy with the results so far
http://youtu.be/51g-lSRkUIQ
