#1201
That diff looks good! Very beefy.lol Do you have a link for where you got that?OH no, what am I asking for
![]() ![]() Anyway, I'm sorry to hear it isn't going as planned just yet. I know you will get it dialed in shortly! |
#1202
![]() Quote:
I did look around for needle bearings. Cheaper too!! I did think about a sleeve for correct sizing. Yup Steve, you might be correct on a traditional drivetrain ![]() Hey reg, where is it that you showed building a axle housing? Lot of pages to sort through, and builds,, I might have to go back inside house and aww over some of your past builds again. I like my idea of using the plastic housing I got but, plastic in this things drive? I might not be able to live with that ![]() ![]()
#1203
Haha. I'm on a strict diet of non RC saving at the moment so I'm trying not to be misled by you building something fun...I can't help myself though, it's a disease... Maybe my current idea will also sway your attention and then you will likely be banished to garage for quite some time... We all get feeding off one another and this just gets scary....
I have built diffs a few different ways. The Tigercat and Euclid involved welding together machined parts for the housings and the 850 KW the main housings were machined from a solid chunk. Euc and KW have removable "pumpkins". The skidder has welded centers and the axle tubes come off. This type would probably work and look more realistic for the type of build you are doing. Not only that you won't have days worth of machining to redo if drilling the axle tubes doesn't go well on the first try. ![]() |
#1204
Not very informative or a great job even for that matter but it may give you an idea. I didn't have a mill when I started this project so I would have done things a little different that's for sure but it does work OK.
http://rctruckandconstruction.com/sh...light=Tigercat |
#1205
is very nice work
the rubber you have use to made the final tires is a Vytaflex® 30? |
#1206
![]() Quote:
https://www.alumilite.com/PDFs/New%2...lex-Series.pdf Shore hardness of A40 , guess the hardness scale is the "A" and number is 40 so A40. Said to be similar to wine cork.
#1207
Your concern of differential slip with a two motor axle? As long as you're not running at full power, then there's some give, like a limited slip posi, between the two motors... that's what I've found with either a 4 motor front loader or a 6 motor ADT, half throttle & machine turns like open diffs.
#1208
#1209
Would like to add to the 2-motors-1-axle discussion, but I cannot find the reference. It was posted by one of our European friends (I think on this forum) explaining that if the two motors are on opposite ends of the same axle, they should be wired in series, and when under load, the motors will create an "electrical differential" by splitting the power proportionally, based on individual motor load and RPM. If using multiple axles with 2 motors each, series wiring on each axle and parallel wiring from axle to axle.
Perhaps someone else read this or the author of the post may see this, so we can find the original discussion. Ken
Big iron is awesome! |
#1210
Thanks ken, always appreciate input. How I had originally thought of powering them was independently, two motors, two esc's. I can understand the wireing concept of parallel and that would make sense. I would think that wireing them in series would put more strain on first (in the series) motor. But do understand the concept of "electrical differential". Hummm, I do have six tires of correct size for a future articulated dump truck,,,,,, that would be perfect to implement on.
If I would have made the inner diameter of this trucks tires about 1/2" less I would have had more room for axle/bearings/wheel shafts. But still the compounded length of opposing motors still put it on the limits. If those darn slim bearings weren't so expensive I may have continued on that path. Couple other factors, dadsgarage haul truck has proven to be powered with one motor and that opens up a lot of the design options for axle (again to understand that I'm by far any design engineer) and my limited brain power ![]() Haven't had much time lately and the RC funding is dwindling, have to make things a little smarter, ( not have a handful of new spare parts) as my wife and I are going to be moving. Moving about 100 yards,, trying to purchase my fathers house (old farm property) and the bank just doesn't understand when I tell them I outright own a 349 excavator, d11 dozer, several rigs, and about to acquire a large haul truck. Kind of funny to say to the loan officer as reply to "what assets do you have" lol!!! Yeah that went over like a lead balloon!!!
#1211
Sounds like this guy on the island might live close to me. I've heard of him before and I'm sure he would try to help you. If you get into contact with him could you pass along my email to him. I also need a good builder for some projects...
I'm glad to hear things are progressing next door. Your gonna need that property if my new toy flairs up an old fire in you ![]() |
#1212
![]() Quote:
![]() ![]() ![]() That is if that's the new toy. ![]()
#1213
![]() Quote:
#1214
So does that mean you bought that Hayes that you and the wife were driving around?
What ?? you didn't say how many wheels it had! ![]() ![]() ![]() ![]() |
#1215
Reg is getting even bigger on the scale toys!!! Lol!!!
Got a little more done on the axle. A lot of turning time on axle parts. I found a way to bolt them together rather than needing to weld. ![]() ![]() ![]() Needed to make the parts beefy,, I think I'm accomplishing that ![]()
#1216
#1217
So tires ended up being about 2-1/2" X 9"? That's a bunch of rubber! Really nice job with the casting and using 3D printing for the pattern. Amazing how all the new technology is making more builds possible with really great detail.
#1218
Haha, no Hayes truck for us although my wife wants one. I think the only way you could get that one from the owner is by buying it from his estate.lol It has a good home now and will be well taken care of until he's gone. Hopefully after that who ever ends up with it will respect the old girl and not turn it into scrap. He did show where the keys are though...
![]() Rub a Dub! Great job on the tires! I am so impressed with how well they turned out. You continue to be my hero... |
#1219
awww thats nice the aluminator is paying captain silicone a compliment LOL
tires look great nice and heavy |
#1220
![]() Quote:
Coop like em heavy and soft in the rear... |
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
