Old 07-08-2011, 04:06 PM
td9clyde td9clyde is offline
Dozer Builder
Default Re: CAT 535C Grapple Skidder
nice work isn't it cool to see everything work like it should when it is built?......nice job and well done
Old 07-27-2011, 06:11 PM
Snochaser's Avatar
Here's another video. It seems my problem is a low voltage supply causeing the speed control to act up. Anyone have a good replacement to recommend? I am using a sabertooth 2-25a.
Ben
Old 07-29-2011, 01:58 AM
tracksntreadslou's Avatar
Hey ben add another seperate receiver pack ..Had that same problem
Old 07-29-2011, 09:44 AM
Snochaser's Avatar
So Lou, 2 receiver battery packs?
Ben
Old 07-29-2011, 10:19 AM
JensR JensR is offline
Edit: Just saw that you already run a receiver pack. Unless this is very weak, my following text won't apply to you.
If you are relying on the ESC's BEC and your servos draw a lot of current, the BEC might break down, which shuts off the receiver and hence the servos' current draw. Then, the system comes back to life, with the control stick at whatever position it was and the self-learning ESC takes this as the new neutral.
So maybe, all you need is a stronger external BEC?
I use 5 cells of my 12V pack (it's actually a double 6V pack) to power my receiver. Not ideal, but enough grunt.
Cheers
Jens
Old 07-29-2011, 02:53 PM
Where did you get the tires from? Are they about 30.5-32?
regards,
Frank
Old 07-29-2011, 03:46 PM
use a 5v voltage regulator and eliminate the need for receiver packs. U can buy them for under $2 at radio shack.
Old 07-29-2011, 04:33 PM
I am not familiar with RadioShack's products, but if you mean the simple 3-pin electronic part that regulates the input voltage down to 5V, this is not the ideal solution:
They typically do not cope with the high currents modern servos need and they are very inefficient, as they waste the extra power as heat. A proper BEC would be better - or a strong battery, if the space is sufficient.
If you know of a 2USD part that does not suffer from the disadvantages I mentioned, could you please provide a link, I'd be seriously and honestly interested.
Old 07-30-2011, 10:19 AM
Snochaser's Avatar
They are Proline Mashers (discontinued)
Old 07-30-2011, 10:21 AM
Snochaser's Avatar
I have run it for 10- 20 mins with the steering servo unhooked without any problems. So my problem does lies with the introduction of the servo. Any suggestions?
Ben
Old 07-30-2011, 12:18 PM
footprint footprint is offline
footprint is on a distinguished road
Could be the servo, ive have 2 that make my DX7 go nuts but also could be the high current load. Id try another servo (unmounted) to see I had a look but couldnt see how easy it was to access and swap that said its a fair bulk to shift mechanically.
Im guessing $2 part mentioned is the 2905 IC these are limited to ~500mA - not enough for your requirements.
Old 09-19-2011, 10:14 PM
Snochaser's Avatar
I guess I have killed my steering servo (Hitec- HSR-5990TG) at Indy. I just took it apart tonight, makes noise but no movement. The gears all look good inside, I'm not sure is wrong.
Heavy Duty or RC farmer- if you wouldn't mind can you post the video you guys got of it in action while @ Indy here for me. I don't have much or very good video of my own.
Ben
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 11-24-2011, 09:39 AM
Snochaser's Avatar
Here are a couple videos shot at Indy . Thanks rcfarmer
http://s60.photobucket.com/albums/h1...t=MVI_2841.mp4
http://s60.photobucket.com/albums/h1...t=MVI_2843.mp4
R.I.P. FGD
Never Forget- 343
Old 11-24-2011, 12:58 PM
carp carp is offline
Good videos snowchaser! as to your low voltage problem it maybe like jensr said and you need a seperate regulator to run it or if the servo was already on its way out it will sometimes draw masses of current causing the same low voltage effect, id send that back to hitec and see what they say $120 hitec servo shouldnt go bad like that.
Old 01-01-2012, 01:32 PM
Snochaser's Avatar
I believe I will send the servo back and see what they say.
I installed some "glass" finally, and updated a pic or two.
Video:
Ben
R.I.P. FGD
Never Forget- 343
Old 01-01-2012, 01:47 PM
bigTdozer bigTdozer is offline
bigTdozer is on a distinguished road
Looks just too awsome to get it dirty lol
Old 01-02-2012, 11:47 AM
Snochaser's Avatar
Thanks. I've had some very frustrating moments with it, but I believe I have all the kinks ironed out now.
Ben
R.I.P. FGD
Never Forget- 343
Old 01-22-2012, 09:26 PM
Snochaser's Avatar
Do you guys find you enjoy building stuff then realize the fun is building and just assume sell what you've built?
R.I.P. FGD
Never Forget- 343
Old 01-22-2012, 09:38 PM
I do enjoy building more than playing with it when it's finished but what is this selling thing you speak of? Unfortunately for me selling isn't in my vocabulary.lol
Reg
Old 01-22-2012, 10:02 PM
Ben , I get bored fast running 1 thing . So , I keep what I build , just keep building more
