Old 02-09-2011, 11:39 AM
Default Re: 2 IH 433 payscrapers (ps433-2 moves)
well lucky for me there's nothing wrong with the mill now I just need phase conversion for the spindle turns out I forgot a wire when separating the control from the power switch for the whole machine .
IHSteve
Old 02-26-2011, 06:46 PM
I'm wrapping up my highway truck building and coming back to my construction equip. . after sometime on pondering this build ,I decided to change the motors ( to slow ) When I got the motors , I over looked the output speed of the motor being reduced by the differentials . since I'm taking the motor I was going to use in the TD40B I need replacements these are the right size to go side by side and got plenty of room to play with gears ratios and multi-speed trans. Also I'm going to bite the bullet and buy the hydros .
Steve
Old 12-18-2011, 10:43 PM
I put this back on the bench after I saw Steve do a motor swap on his tunarocker I had 2 motor siting around with double the speed as the original , so did a motor swap and Stevie is a happy camper I was going to try to get it going for cabin fever and supprise everyone but As always not enough time to do both pan and mack we'll see how it goes though
Old 12-24-2012, 04:02 PM
I got er done but It shrunk
did some push with the 25
I needed this to get some details figured out in the gooseneck area and the steering . Looks like I'll be needing to remake the gooseneck to get the steering right
Old 12-24-2012, 04:09 PM
td9clyde td9clyde is offline
Dozer Builder
i seen those at tri state tractor show lol nice try Steve can't pull a fast one that easy nice models though
Old 12-08-2013, 10:04 PM
now I know what was under all that dust in the corner
I started on remaking the gooseneck . The block in the vise is 5"x3.5" x 24" still need to finish the top and flip and cut the underside out .
till next time
Old 12-08-2013, 10:31 PM
I was getting worried about you! I thought you were too busy making money and forgot that you have to build yourself some stuff to keep it fun. All joking aside, I'm happy to see you milling some parts again for one of your many projects! It's not the same around here when we don't have your "updates" to look at.
Snochaser's Avatar
Keep the chips flyin'. Pokie!! Looks good.
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
Old 12-09-2013, 09:18 PM
making $$ problem is I enjoy makin stuff that I get to many ideas goin at once . I know I can make this werk just need to keep at er .
thanks ben waitin for more brass to come in
Old 12-09-2013, 09:33 PM
More setup pics, finished part - the welding , and comparison pics
first is setup to face the outside . I don't have a sine plate so a lil improvising the facing was done manually no need to waist time programing that I did a lot of setups do to what I had in long (lack of ) length end mills
cut out last op
what I couldn't do with the 1st neck
1:25
comparisons
cpt jack running the 1:25
till next time
Old 12-09-2013, 09:43 PM
I did make the new wheels for it over a year ago (dust )just never posted them . The caps are programed just need to put a plate in the vise and cut .
Old 12-10-2013, 10:39 AM
Stefan Stefan is offline
Great work!
Old 12-10-2013, 11:00 AM
Glad to see your back at this one!!! Cant wait to see more shavings flyin
Old 12-10-2013, 11:55 AM
I love watching parts being machined. The new neck looks great, and I like those models too. First Gear replicas?
Old 12-11-2013, 07:08 PM
Nice work steve-your old part probably looks more like the real thing from the old days . CNC makes a nice part though.
Old 12-11-2013, 07:16 PM
Dieselchopper's Avatar
Looking good, just not so sure about your operator choice..........
Old 12-11-2013, 07:31 PM
dirtpusher9's Avatar
Moderator
Well, these scrapers may get a life after all. Nice work Steve.
Old 12-12-2013, 03:26 AM
404's Avatar
404 404 is offline
404 is on a distinguished road
It's ok, he has a keira knightley doll for the other one.
Old 12-22-2013, 10:39 PM
yea eventually other things been taking precedence . Which can be good and bad at the same time . room is a big issue on these I want to do the trans and diff arrangements but where to put the rest of the components Gear motor axles are looking more practical
Old 03-27-2014, 08:08 AM
JAKEBRAKE's Avatar
JAKEBRAKE JAKEBRAKE is offline
JAKEBRAKE is on a distinguished road
Very nice build, I wondered how it was going to take to see some scrapers being built!! I can't to see a video of these scrapers working together!!
