Old 06-12-2016, 01:22 AM
Default Re: LilGiantsConstrCo
Thanx Tom. The equipment has worked exceptionally well with only a few minor repairs that were fixed same day. Initially the dig has been quick, but lately has slowed down greatly with precision digging.
It took many lipos to cut this section of the wall straight.
Decided to go back another 4 foot, this should make the dirt ramp something less than 14 degree.
The 1st step has a depth of 8 inch & LxW 36x12... onto the next step with same dimensions.
I'll get a couple of sheets of 1/2" pws on Monday to cap the dirt stairs with. I still have a small pile of pea gravel left over from last summer's cement work, a short haul to the east of shop to use for base under the wood steps.
Old 06-12-2016, 01:56 AM
jack van's Avatar
jack van jack van is offline
joe are your stair standard measurement of 7.5 inch rise and 10.5 inch tread ?
Old 06-12-2016, 02:05 PM
I gave the measurement above, so... no, but close enough. I got the measurement from 3 different sets of stairs in my house.
Old 06-12-2016, 02:20 PM
Good thing you didn't mess up and built it in scale 1:14
Old 08-01-2016, 01:07 AM
Not too much accomplished in the last month... weather is too nice outside to spend much time inside.
Quite a bit of rain in June & just not having any luck getting a hold of eave trough guy, the excess rain was starting to wash the dirt away from the tunnel wall laid down this sheet of plastic June 27th & no more water problems since.
Old 08-01-2016, 01:09 AM
You can see the eroded the cement pillar, 2nd from the end wall, better view of it in the vid. Month ago I propped a sheet of pws against pillar & shovel a lot of dirt in behind, not all of it stuck though. Those cement pillars go down 12 feet, so no worries of it moving.
The orange string you see (baler twine), once I get the bottom dug out, set the string in place so I have something to eyeball as I cut the ramp to a more favorable grade, about 12 degrees.
Starting the 3rd row on the pile
quick vid from today's activities
https://youtu.be/ejYH_3f4dgg
Old 10-04-2016, 11:11 PM
I cut that hump out at the top of the ramp which made for a much more favorable grade @17 degree, not sure yet if it's the final grade till I get the very bottom dug out, much easier pulling loads out now with next to nothing rolling off back of adt.
Old 10-04-2016, 11:27 PM
Too awesome. Need to get yourself a swiveling captains chair in there. Too much serious work going to be squatting on a 5 gal with a throw pillow!
Old 10-05-2016, 12:19 AM
HAH! I'm easy to please & it's easy to move around.
Old 10-05-2016, 07:20 AM
Looks good Joe, So what are you going to do all winter? Found the picture of the snow, figured with the way the radar looked you were getting a little white up there.
Old 10-05-2016, 03:04 PM
Oh there's lots of digging to do yet Kent & with digging on two different grades it's really tricky & slow for the 850 to maneuver in the confined space. Plus I got a shyt ton of building to do this winter for what comes next after the tunnel is completed.
Kinda looking forward to getting out of this wet sticky clay too, it's really hard on tracked equip with the tracks gummed up all the time... I've lost count of the number of times I've taken the 850 tracks off to soak in water to dissolve the packed clay from them.
Old 10-05-2016, 10:59 PM
wow its looking great Joe!!
Old 10-13-2016, 02:53 PM
3 or 4 more stairs to cut in yet.
https://www.youtube.com/watch?v=nEdS9RhAfUk
Old 11-17-2016, 04:53 PM
Doing a lil dozer work today flattening out the piles so the B50 can climb & start piling on the next layer.
Did a bit measuring in the tunnel today too, I think it's + - 2cyd to the finish line, could be done by xmas.
Old 11-18-2016, 05:40 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Hi Joe
Look forward to more progress on your work as time allows.
Great work as ever and you will have to come up with a tunnel break through completion ceremony.
Thanks for posting
Regards
Mark
Over the Pond in the UK
my weather station
Old 11-18-2016, 07:21 AM
Joe, What are you going to do with all the dirt piled that high?
Old 11-19-2016, 10:27 AM
mog mog is offline
your sure are making a nice head way. next year we are going to have some dirt at the show again.
Old 11-19-2016, 03:17 PM
I suppose that'll be the 1st load hauling out of basement video Mark via the new "think of name" tunnel... got any ideas?
Screen & crush Kent to keep the rc activities going... plus there's still 30 some cubes to come out of the basement floor yet so I'm not dinging my melon on the ceiling anymore.
Thanx Martin... these late late fall harvests need to come to an end soon so I can get out to the show again.
Started today cutting final grade on the ramp, 1" in spots to 1' in others... it sure would've been nice if that grinder idea I had last yr would've worked better. Hopefully I don't create too many potholes with the ripper.
Old 11-26-2016, 11:48 AM
Hofabooz's Avatar
Hi Joe
names for the video
We could have escape to next door
Canadian digs for victory
Fianl break through or Break out
Grass is green on the other side so we dug this tunnel
Hey Joe i dont know i just know that it will be great to watch.
Regards
mark
Regards
Mark
my weather station
Old 12-05-2016, 02:33 PM
I was thinking moreso a name for the tunnel... I'm still drawing a blank
What I've been working at lately, getting the walkway dug out. I can walk through on the ramp without bending over much, which is handy that the weather is now -20's
The camera doesn't show depth perception very well, it may look rather flat, but it's a 35 degree decline leading into the tunnel entrance.
