Old 03-20-2016, 09:59 AM
She's a beautiful beast RW!
The esc might be a little jerky right now but I wonder how will it react when fully loaded. I wonder how much dirt this thing is gonna haul? 70-80 lbs?
Old 03-20-2016, 10:49 AM
You've finally reached my favorite part! The body! Great job my friend. She's one of a kind!
Old 03-20-2016, 01:51 PM
Your a sicko reg!!! Lol!! Your favorite part is my hair pulling, better hit the distributor for a couple cases of beer, oh crap-do I have another piece like that, I know I measured that correct, ok what's on tv, part of the building process!!
But slowly gettin-her-done!!
Old 03-19-2016, 08:24 PM
Seems like all systems work well Cooper!! I hard the noise the 1st. time I watched it but did not know what it was. Guess that is a problem but you can fix it. Really big truck!!!!!
Old 03-19-2016, 08:50 PM
At least it is something I can easily identify. Haven't looked into what options I have for other driveshafts. I think she is going to be operating at slow speeds anyway. I'm not completely happy with motor/ speed controller. I may look into something along the lines of rock crawler. Maybe even a sensored motor/esc. Would be easier on drivetrain with a more controlled start up. This one doesn't want to start very slow. Kind of like a blast on initial start rotation. That should be mostly the esc.
Into the joy of body work. At least no complex curves!!
Old 03-19-2016, 10:09 PM
steamer's Avatar
steamer steamer is offline
RW, trucks looking awesome!! I'm amazed at the short turning radius it has and I wish mine would turn like that. Boston gear make a bunch of universal joinst that would work in your truck. I've used them in my 3/4 scale SD-40 for over 20 years and never had a bit of trouble. Run up to page 100 and they start from there.
http://www.bostongear.com/pdf/open/5...en_gearing.pdf
Old 03-24-2016, 10:36 PM
Some time today, picked up this smaller torch with a flex head ( all yours reg )
It is a lot easier to hold after I get past the small shock from shortsleves!!! And slowly getting the hang of tiggin
And some of the progress on upper deck
Old 03-24-2016, 10:50 PM
Awesome! I need to take my own advice and buy one of those flex heads for my 150a torch. It looks like the cup is shorter on that one as well? What brand is it? I try to buy stuff locally but it can be a joke. Either pay way too much and get it or find a reasonable price but they won't order it until they place a massive order in 6 weeks or whatever. Now that I am more current with online shopping I guess I should take a look.lol It's kinda cool to finally see someone else welding aluminum body parts together! Keep the updates coming!
Old 03-24-2016, 11:02 PM
Obviously I'm not to experienced in welding but I picked it up off eBay. Had the correct dinse connector and quick connect gas fitting. Was a plug-n-play item. I purchased separate gas lense collets/cups for it. A friend told me a gas lense has better gas coverage and easier to use by having ability to extend electrode a bit farther out. Anything to help me with the eye hand control and being able to see what I'm doing better. It's a wp9 torch and using 13n collets/lense.
Old 03-24-2016, 11:07 PM
Haha, just jumped back over here from eBanger. Stuff is cheap on there compared to local. Going to hit "buy" on a few things. Thanks for the kick in the azz.
Old 03-27-2016, 10:40 PM
DADSGARAGE's Avatar
Great job on building this truck, and those tires you made for it are a perfect fit, they really add to the scale look!!!
Old 03-24-2016, 10:44 PM
Mikem Mikem is offline
Looking good . Tried welding steel today and way out of practice ! Mike
Old 03-28-2016, 09:22 PM
Got cab taped, have some details to cut in before welding together.
Old 03-29-2016, 08:08 AM
Very nice. You can just fuse those seams together without filler but you need to be careful not to round over the sharp edge or you will need some filler to grind off.
Old 03-29-2016, 12:39 PM
I'm still at that point that I don't know when to back off more , in an instant the edge is gone. Just need more time doing it I guess. I've been trying to add as little as possible on the filler, I guess it's a lot like drywall, the more mud you put on the more you have to sand off. How often do you change how much gas is coming out? I've been having a hard time on inside corners and I'm thinking I may have too much gas flow as arc gets a little erratic and wanders. Does that sound correct? I've set up between 15-20 for flow. I don't know if that is what's coming out of torch as the gauge and flow meter is at tank. I don't have one of those to slip over torch. And from what I've been reading a lot is knowing how to read the arc and what it's doing to dictate what setting is needed. I'm using gas lense.
Old 03-29-2016, 11:07 AM
i can't wait for the pic of the 4200 curled in the bed of this monster
Old 03-29-2016, 12:50 PM
Me too!! I have to secure the top plates down and make sure cab is in correct location and then I can start bending up the bed. I don't want to weld much together yet as I need to cut details in while pieces are apart and easier to clamp down. And am still unsure what I'm welding together and bolting together to be able to have somewhat easy access to taking apart for maintenance. Still unsure if I'm making the dump body out of steel or alum. Sheet alum is easier for me to clamp down and cut than sheet steel. All hack saw and mill, no band saw. Maybe next year a variable speed metal cutting bandsaw under the Xmas tree,,,,yeah and me lucky charms will be shooting out my arse when that happens. !!! . That was my thoughts after chatting with my Santa , she wants a new vehicle, well I found one for her if that's how she wants to play
Old 03-29-2016, 12:51 PM
Even has nice racing stripes and is very economical on fuel!!!
Old 03-29-2016, 12:59 PM
Bo Wallen's Avatar
Exclamation Re: Great Dane excavating co.
I see you looking for more Garage time ..l A couple cans of beans an the afterburner get her where she needs to be...
Old 03-29-2016, 01:21 PM
Your looking real good and moving right along it will be done in no time at this rate. Ed
