Old 02-16-2017, 09:52 PM
Default Re: LilGiantsConstrCo
Being storm stayed a week or more doesn't bother me at all, just keep track of the forecast & prepare in advance.
This week's shop project was making a welding table...
The table is 4 x 6 feet, top sheet is 3/16 thickness, I built it for building models. Sitting down to weld I'm steadier now with the tig, welding steel or aluminum is much easier.
Time to start making trls for the 4206.
Old 03-13-2017, 01:56 AM
Made a new cage in aluminum for my JD850's rotary screener... the welds aint pretty, but it's not coming apart either What a difference in agility a few less lbs makes hanging out on the end of an out stretched boom
Got a quick-tach coupler for my SA 963 & STahl WA500, plus 4 buckets & the U blade, plus an adapter for the Braeker lock for oem Stahl bucket. Mr Braeker sends out the necessary glue for the stainless steel, but I need to provide my degreaser as that's a hazardous goods that can't be sent in the mail.
In the shipment Mr Braeker sends a note that the instructions are provided in PDF on his website & gives a username & password to the buyer to access them.
Mr Braeker's suggestion to use 120 grit to buff the stainless steel with before gluing & painting.
Old 03-13-2017, 12:09 PM
Efroeh Efroeh is offline
Those attachments look good. Which buckets did you go with? Also how was dealing with him and what kind of price was it to ship to Canada?
Old 03-13-2017, 04:21 PM
avel avel is offline
I've been looking at those Braeker kits for awhile for the LR634. Primarily the aluminum bucket with the short "lip/bottom edge?" for more breakout force and having a lighter bucket.
Looking forward to hearing about your experience putting things together, and your tunneling operation.
Youtube username iamaman27
Old 03-13-2017, 04:31 PM
Mr Braeker suggested the HD Rock Bucket S for the 963.
The tunnel is about done! ...what little is left I'll do in the summer when it's not so bitter cold... just finally feeling better as of today from a two week cold.
Old 03-13-2017, 04:23 PM
quick coupler for Stahl WA500
quick coupler for Scale Art 963
adapter plate for OEM Stahl bucket
leveling bucket L
loading bucket
XHD Rock Bucket L
HD Rock Bucket S
HD Abrasion U-Dozer Blade
Block Handling Fork Stainless Steel
Just sent him an email, he communicates well in english, shipping is cheap! 52,94 euro for 10kg box... shipping out of Europe is dirt cheap compared to anything from the USA... NAFTA is such a farce!
Old 03-13-2017, 10:34 PM
leveling bucket L
loading bucket
XHD Rock Bucket L
HD Rock Bucket S
That's a nice list of goodies. Ya the NAFTA trade deal is bull. That's not too bad for shipping. How does the vat work for us Canadians?
Old 03-14-2017, 02:15 AM
We don't pay any VAT, that's a european tax, but sometimes (depending on amount) you & I will pay our own pst & gst, although I wasn't charged anything on this parcel from Mr Braeker.
Built the two quick-tach couplers
Then made the fork
Then tried each quick-tach coupler with the fork to be sure everything works as it should.
It says in the instructions to not glue anything until all pieces are fitted together... well my clumsy fingers were having quite a time making that happen without pieces falling out of place, so I glued a few pieces in early steps... then discovered at the end why that was a bad idea. ...a bit of trouble fitting the last piece of the puzzle, but I got er done with a bit of careful filing.
The next quick-tach coupler went together much easier & I didn't glue nothing till every piece was in its place.
A top quality product, buy with confidence.
Got some farming to do next couple days, build the buckets on the wkend.
Old 03-14-2017, 11:06 AM
Those look great. I wonder if the servo will interfere with anything as it seems to stick out a bit. I went on his website he must be using a small ram to lock it in. Looks good either way. Are you gonna be painting or getting them powdercoated?
Old 03-14-2017, 11:31 AM
I'm sure he's got servo location figured out, these quick-tach couplers have been available for yrs, I've seen many of them in videos from all over the world. The hyd cyl is another option, if you wanna go to the added expense of adding an aux valve. No powder coater nearby. The quick-tack coupler I think I will leave stainless unpainted so the moving parts always move freely, won't paint the fork either. The buckets will be yellow, tape off the quick-tach area so the paint don't cause any problems with coupling.
Old 03-14-2017, 05:58 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Very impressive, gluing metal together, TO COOL ! Thanks for the information Joe..
Greg
Old 03-16-2017, 01:23 AM
XHD Rock Bucket L.... about 2 hrs sanding, deburring, cleaning.... then 3hrs so far gluing, just a couple pieces left to fit & glue.
Old 03-16-2017, 01:40 AM
tracksntreadslou's Avatar
Wow Joe looks good .curious to see how well the glue stands up..I wonder if there is a way of cleaning the adhesive off if needed ..sure if you wanted you could tig weld some spots .good to see you in the shop making stuff ..Like the new welding table ..will help to keep a good steady hand .
Hows is the weather co-operating .I may have to make another road tip there soon ..I will keep you posted
Old 03-16-2017, 02:25 AM
Methel ethel keytone, should cut the glue, or heat it.
Cheers!
Old 03-16-2017, 01:05 PM
That bucket looks mean. I'm sure the glue will hold up well.
Old 03-16-2017, 01:31 PM
Bo Wallen's Avatar
Thumbs up Re: LilGiantsConstrCo
Great project going there. looking forward to see it in action.......crunch crunch video time maybe .........
Old 03-16-2017, 01:39 PM
rc13's Avatar
rc13 rc13 is offline
rc13 is on a distinguished road
Nice Job. It looks like you are on a mission to get those attachments built. Tobias has refined his laser cutting to reduce those burs. That helps a lot with time. Makes it much easier.
As for the questions about the glue holding, I have the same HD Bucket that I use on my 966 sometimes. It is as solid as can be. Loctite 435 is amazing.
Old 03-16-2017, 04:19 PM
That's right Neil, in the instructions it says acetone will dissolve the glue, and if the metal glue nozzle blocks up, a quick bit of heat from a lighter will solve that.
The sheets are 1 to 2mm thick, my tig skills need a lot of refining yet before I'd try tig'ing something as polished as these buckets Lou. The weather warmed up Tuesday to hi's of +5 or more, looks like it's sticking around awhile, hopefully for good... got a lot of work to do prior to seeding that's about 6wks away. Oh man, did I dogf/k the winter & didn't get much accomplished.
Bo, the way youtube has changed it's resolution settings, my old gopro looks blurry even with it's hidef setting @ 200mb/minute, my video posting days are pretty well done with just a wireless connection, too slow & too costly!
rc13 (forgot your name or maybe you haven't told me, can't remember ) Yep! only couple wks left of winter hobby time, hopefully get all these buckets done by the wkend... grain hauling this week got postponed b/c of the sudden warm up to next week, hopefully my yards are dry then.
Finished up the XHD rock bucket L this morning
The brass bolt detail is glued in
Moving onto the XHD rock bucket S (this is for the Scale Art 963), the smaller sheet had a lot of splatter from the lazer cutting on one side, chewed up the orbiter sand pad a bit to get it buffed out. Wipe clean/degrease with acetone... twist the parts out... file where needed... start fitting pieces together... maybe by 5pm have another one done
Old 03-16-2017, 04:51 PM
Bo Wallen's Avatar
Lightbulb Re: LilGiantsConstrCo
"Bo, the way youtube has changed it's resolution settings, my old gopro looks blurry even with it's hidef setting @ 200mb/minute, my video posting days are pretty well done with just a wireless connection, too slow & too costly!"
That sucks......ugh. Was hoping for more entertainment. They Don't make things easy for Guys outside town anymore. I was Googling High Speed Internet in Canada.......O'boy no fun reading at all........I understand your frustration.
Well there is one reason to start planning a road trip.......i wanna see more of this continent anyway. And your great project i've ben following for many years by now.
Old 03-17-2017, 11:46 AM
That sucks your not gonna be posting videos anymore. It is a Hassel to take the video, edit it, and then upload it. If you would mail your edited videos to be I'd gladly upload it to YouTube for you Joe. One bonus living close to a city is high speed Internet.
Currently Active Users Viewing This Thread: 35 (0 members and 35 guests)
