Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > RCP’s Aluminum Gravel Boxes and Accessories
RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more
Old 04-15-2016, 11:47 PM
Default Re: Vertical Ribbed Dump Trailer
It looked OK Mark. I don't believe I took any pictures of it though because I'm a dumbass.lol
Old 04-15-2016, 11:49 PM
Northern Farmer's Avatar
I'll take some when it gets here.
Old 04-15-2016, 11:55 PM
You can see it here a bit.
Old 04-22-2016, 06:19 AM
Talking Re: Vertical Ribbed Dump Trailer
Look what arrived yesterday! I couldn't be any happier with Reg's work All the details put into this trailer and the quality! I mean daamn I found myself staring at this trailer all night fantasizing hahaha
Time to get dirty polishing this bad boy up!
Old 04-22-2016, 07:14 AM
thats going to take awhile!!! make it shine
Old 04-22-2016, 07:16 AM
No doubt...will pace myself lol
Old 04-22-2016, 08:20 AM
Steve's wheels really help set it off!
Old 04-22-2016, 02:20 PM
Looks so real and the wheels are a perfect match to the rest of the trailer.
Old 04-22-2016, 07:13 PM
Thanks Claus!
Old 04-22-2016, 08:24 PM
hey i don't want to be that guy,but did reg do a test polish on all
the parts?? I've had some aluminum parts that just won't shine
Old 04-22-2016, 08:33 PM
I shined up one rib. Does that count? I think it will all polish up but it's going to take forever. I would bounce those new steel excavator teeth off of it a few times and leave it the way it is.... But then again I'm lazy.lol
Old 04-22-2016, 09:39 PM
Honestly when I received it and was looking up and down the aluminum I was pretty impressed already with the finish but I won't be satisfied until I need shades to fill her up!
Old 04-22-2016, 08:57 PM
the truck wash guy uses acid on our trailers so we don't shine
Old 04-22-2016, 09:02 PM
Hey, I have a question. I found an old Alcoa wheel at an abandoned logging camp recently. It's got a small crack in it and its badly worn on the bead but I want to shine it up and hang it on the shop for a hose holder thingy. It's quite ugly so what should I start out with? Is there a cleaner that will take off some of the crap or should I just start sanding? PS, I hate polishing...
Old 04-22-2016, 09:36 PM
Seems to polish well just spent 5min. hand polishing the cover of the tarp motor
Old 04-22-2016, 09:42 PM
you have a redi mix yard near you? if so see if you can get some
acid from a driver. it will bleach the rim white. then start scrubbing.
i use grey matter with a red scotch pad and a orbital sander follow by a
grey pad till smooth and shiny....... But thank god the wash guy uses acid
so i don't have to bust my a$$
Old 04-22-2016, 10:04 PM
Acid! I'm gonna stick with what I know has worked for me in the past Mother's aluminum polish that I get from the local hardware store. Either I do it by dremel with cotton polishing wheel and rouge compound. I have a larger electric motor and polishing wheel but don't want to use on the trailer...only has one speed and when you loose grip of the part (tends to happen handling smaller pieces) off it goes like a bullet! Often damaging the corners of the piece
Old 04-22-2016, 10:08 PM
Mark was talking acid because of my old crusty wheel not your trailer.lol I wouldn't use acid on your trailer either.lol
Old 04-22-2016, 10:10 PM
Lmao my bad
Old 04-22-2016, 10:17 PM
cover looks good.
I'm in road salt, blue stone dust, cement powder
and sand all day. it beats the **** out of the rims and trailers unless you
buy the clear coat that Alcoa uses on there rims and alumabrite finish trailer
then you can just use soap and water and a spray wax
