Old 06-28-2011, 05:15 PM
D8R D8R is offline
Default Re: CAT 14M Motor Grader
Wow, this model is getting better and better. The quality of fabrication is very high, hope to see this model some day!
Dan
Old 06-28-2011, 05:52 PM
Vanisle Vanisle is offline
I have nothing to add except ... that is some amazing workmanship!
Old 06-30-2011, 08:24 AM
I love all the intricate profiling on those lift parts!
Old 06-30-2011, 08:56 AM
Only 1 word for this entire build-WOW!! Just too bad you do not live in the States
LYNN
Old 07-01-2011, 07:11 AM
I got the lift cylinders done
Old 07-01-2011, 08:06 AM
Ari, you might have said already, but how many valves/channels you going to be using on this?
Good progress by the way..
Elliot
Elliot.
Old 07-01-2011, 08:25 AM
JensR JensR is offline
Your speed and quality are both absolutely amazing!
What ball heads are you using?
I wasn't impressed with the metal heads I found (either not enough articulation or the ball would pop out too easily), so am back to using the Tamiya plastic ones, which are strong enough for me needs...
Cheers
Jens
Old 07-01-2011, 08:41 AM
Elliot
Just made a quick calculation, and it appears the there will be 7 hydraulic functions/valves + blade rotate control, drive motor control and all the possible electric switches (sound, lights, rotating beacon...)
It appears that I don´t have enough channels on my radio
I will make all the hydraulic cylinders functional but I might not be able to use them all.
JensR,
I´m using these rod ends: http://store.rc4wd.com/Aluminum-Mini...l-1_p_637.html
Old 07-03-2011, 09:30 PM
You keep posting new progress and I keep watching intentively.
...and hoping you're making two of everything as you go.
Old 07-03-2011, 10:17 PM
Great looking Grader. I'm curious about the weight. I fear you might not have enough weight to make it perform up to your design standards.
Old 07-04-2011, 05:40 AM
I´m estimating the weight to be little over 10 kilograms, is that enough, will just have to wait the test drive results
I got the wheel lean cylinder done. It was very difficult task to do, due the limited space for the cylinder lenght. I use only one o-ring in the piston and in the rod seal, to get the cylinder as short as possible. It has total of 18mm stroke. It appears to be holding the pressure (15 bar)
The wheels lean a bit more to the other way, but will just have live with it
Old 07-04-2011, 11:23 AM
rc_farmer's Avatar
Master Builder
Ari, you are doing a great job. As far as weight, i don't think you will have a problem, since yours is made from aluminum. You're looking at about 22lbs @ 10 kilo. You may have to add some shot to the tire for traction. I have not weighted mine out yet but I think it's tipping the scale somewhere around 35lbs.
Keep up the good work!
Giving up is not an option!!!
Old 07-04-2011, 07:18 PM
hammer hammer is offline
hammer is on a distinguished road
Ari, awsome job man craftsman ship looks outstanding your attention to detail is insane can't wait to see the finished product.
Tony
Old 07-07-2011, 01:39 AM
I'm just dumbfounded by the level of detail and exactness of the parts you machine. I feel like a broken record because all I can keep saying is 'wow'! This is one of the neatest builds I have ever seen.
Old 07-07-2011, 02:58 AM
Thank you guys again for all the compliments
Got the steering cylinders done
Old 07-07-2011, 08:19 AM
I just can't design and build as fast as you do. So So NICE! You give many of us inspiration and ideas to build. Bravo!!
Old 07-07-2011, 05:01 PM
Excellent, so smooth and powerful
Great how all the functions fit together in the tight space
Will be interesting to see how the steering feel is, if the stick position is proportional to steering speed and not steering position?
Old 07-07-2011, 06:35 PM
rc_farmer's Avatar
Master Builder
I am amazed at your engineering and building talent. Can't wait to see it all work together.
Old 07-08-2011, 07:52 AM
I got the blade tilt cylinder done. That´s the last cylinder for now.
I have to abort the build process for a while, because we are moving to new a house. I must start to pack my machine shop to boxes, not to mention all the rest of the house...
Luckily I´m on my summer vacation
Old 07-08-2011, 08:22 AM
kerst's Avatar
kerst kerst is offline
Looks fantastic! great workmanship!
Kerst
