Old 12-02-2010, 09:34 PM
tracksntreadslou's Avatar
Default Re: Logging & Construction Equipment
Heres the link to their website Steve ..It wont directley link you to the tire but with a bit of searching you will be able to find them under Reifen
http://www.fechtner-modellbau.de/shop/
Old 12-02-2010, 10:45 PM
thanks Lou , that rings a bell
Old 12-03-2010, 08:49 PM
So you custom fabbed that brass tubing and holders, eh? Looks great!
Are you changing the tires on the adt for better looks or are the mammoth tires giving you trouble?
Old 12-04-2010, 04:03 PM
Thanks joe ..I found that making bushings drilled to the size of the tubing worked fairly well ..I had some 3mm threaded fittings so i tapped the the ends and soldered the bushings to the tubing ...I noticed that those european fellas building their vario machines are doing tubing as well...Did your machine come with that stuff or are you going to have to build that yourself.?
The mamoth tires are working great..Im thinking the other tires may add a bit more scale and a little more tracttion.
Old 12-04-2010, 04:11 PM
Yesterday i managed to do a lttle testing and threw a load on the pacific...Dam forman showed up and parked his pickup next to the truck before the binders were put on..
Old 12-04-2010, 06:33 PM
Lou I went in that web site and the only tire I could find was 120 mm tall I would like a set for my Komatsu wheel loader to get it taller so I can load my dump trailer and the 130 mm would help. Is there a part number for them? Ed
Old 12-04-2010, 06:43 PM
Iron Art's Avatar
Iron Art Iron Art is offline
Lou, That shovel looks good, a little paint and its time to go-ah-loggin. Nice work. Fred
Old 12-04-2010, 08:01 PM
kamyoncu's Avatar
kamyoncu kamyoncu is offline
kamyoncu is on a distinguished road
hey forman !!! I loved your pick-up is it axial scx10 basis ? and could you write me brand of cab ? and final question is the inside hand made ? or not where can I get them ?
CAT: 963 B Scaleart // 345D LME Wedico // CS 563 E Handmade
Mercedes Benz: SK 3544 AK 8x8 Premacon // NG 2636 AK 6x6 Wedico Handmade
MAN TGS 26.500 6X6 Wedico - Premacon
MACK Granite 8x6
Old 12-04-2010, 09:07 PM
Brian in PA's Avatar
I'd rather be truckin'
Man you got a lot of work in that Lou! Its looks superb!
Old 12-04-2010, 10:20 PM
RCLogger's Avatar
RCLogger RCLogger is offline
Lookin Good Lou
Looks like another project is almost finished..
greg
Old 12-05-2010, 12:21 AM
Oil Field Construction's Avatar
Oil Field Construction Oil Field Construction is offline
Oil Field Construction is on a distinguished road
Awesome build Lou!! Great detail and it looks great! Time to talk with that foreman... Need some video of that unit before the snow fly's..
Old 12-05-2010, 08:33 AM
The forman's truck looks perfectly sized sitting next to Your rig.
Old 12-05-2010, 10:41 AM
Snochaser's Avatar
Originally Posted by RCLogger View Post
Lookin Good Lou
greg
Yeah...so what's next Lou???
Ben
Old 12-05-2010, 12:45 PM
steamer's Avatar
steamer steamer is offline
Looking really good Lou. Can't wait to see it lifting and swinging some logs. His next job is to put those big arse tires on the ADT. Let me tell you guys they are something else when you hold one in your hand.
Old 12-05-2010, 01:51 PM
Hi Ed those tires are 125 mm..I hope i didnt misguide you...but they would look good on the kamatsu..not sure if the rims would be wide enough though ..anyway they are part # Artikel-Nr.: 5924
Truck was a toy rc dale earnhart ss pickup 2006..Using a losi 1/18 rock crawler chassis...And thanks
Thats the nice thing with loading logs...all year round Kevin ..cheers budd and new vids soon
Ben
thinkin like rob said ..adt tires then get back to the grader build
Thanks rob...cheers
Fred still adding a bit more detail and hope it warms up to paint..thanks
Old 12-05-2010, 02:57 PM
Lou thank you for the information I appreciate it. I think I will give them a call tomorrow and see if they have a tire that would fit the bill for me or maybe they can tell me were to get one. Ed
Old 12-05-2010, 03:01 PM
dirtpusher9's Avatar
Moderator
Looks good Lou, I've not been around that configuration with the crowd cylinder on the bottom side like that, does it have as much power as the other way? Are you using the Jung pump on that rig?
Old 12-05-2010, 03:50 PM
The needed power on the crowd (or the stick, as I like to call it) for the log loader would be opposite to a digger, you're pushing the stick out with a heavy load on the arm, to load the trk/trl... would be my guess for the cyl being underneath.
Old 12-05-2010, 05:40 PM
Right on Joe .
Old 12-05-2010, 06:32 PM
td9clyde td9clyde is offline
Dozer Builder
Looks great!!!Lou you keep it up you'll be crankin out a model every month and a half ,........nice work though
