My seat is "up there", that's the back of my shop.
![]() I got my 1st my hydraulic construction model, Liebherr 922 excavator, from Stahl/Leimbach summer of 2001, finished building it Feb 2002. Basement enlargement project started winter of 04 - 05.
Been working on a new B50 with a pup this winter. I went with brushed motors in this one, it'll run a little quicker than the old one with brushless.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The old B50 needed some attention a few weeks ago, had to pull the pump out to tighten the belt. ![]()
Another B50!
Looks real good Joe nice welds. Ed
looks awsome Joe. your fleet of trucks will beable to move alot of material.
Thanks for posting the pics of the new truck. I’m sure this one will live a life of good use . And nice work on the hitch!!
Wow you built those 1.5 B50's fast!! Does it come painted? Looking forward to this beast hauling dirt.
just currious if you put all the dumper trucks in a line how many feet long would it be lol
Fast?! What are you being funny?
![]() ![]() ![]() ![]() Anyways, just about done with this adt & pup ![]() I made a valve divider block from brass for the pup ![]() ![]() ![]() This dump cyl was on the trk, right side... the flexible hose going to the "T" I think I made it a bit too short, box going up/down - changing angles tugging a bit on this fitting broke it loose from the tube. Pipe goes up to top of tube & broke loose from that soldered joint... buffed the paint off, resolder, repaint, put it on pup after dinner today. ![]() ![]() Got the box on the pup, put oil to the cyls ![]() This is where the connection is for the pup hyds ![]() Got a leak, hoping I just over tightened the fitting & crushed the seal too much... put on a new fitting with some thread seal... give a couple hrs to set & try it again. ![]() Made up some exhaust pipes from 5/16 Plastruct tube for this adt & the others ![]() This air cleaner is 3D printed, used an 8mm magnet to hold it place for pictures & filming, leave it off during regular use so it don't get so dirty. ![]() ![]() And I'm motivated to get busy putting this WA500 wheel loader together next, it's only 4yrs next month that I've had it ![]() ![]() ![]() ![]() Degrease the cyls today & paint them yellow ![]() The drive belt on my lathe is toast ![]() ![]() I was looking on https://www.mcmaster.com/#drive-belts/=1booul2 (I see the link won't go directly to page I was looking at; it's the T5 series timing belt) My operators manual gave the dimensions 124 x 1.5 x 15 which is metric for teeth - depth - width When I measure the length I get 584mm & pitch is 5mm Gonna be one of these 3 belts ![]() ![]() T5-575-16 575 115 5 Urethane Gray -13° to 176° 1679K518 9.10 T5-610-16 610 122 5 Urethane Gray -13° to 176° 1679K545 9.51 T5-630-16 630 126 5 Urethane Gray -13° to 176° 1679K522 9.51
Got er done... well except for the decals & a couple of other bitty parts that'll show up in a few months.
![]() ![]() ![]() ![]() ![]() Missing the fuel cap & fuel drain plug ![]() ![]() ![]() ![]() Off to get the 1st load ![]() Start painting the cab on the old B50 shortly... more than 50cy hauled in the last 3yrs ![]() ![]() ![]() ![]() ![]() Trying to pull the steep grade with pup in tow, the rims on the tandem axle were slipping bad in the tires, I had to pull hard by hand to get the truck up the hill... I really hate gluing tires... not sure what this gasket maker goo will do, smeared it on today, see what it's like tomorrow. ![]() ![]() ![]() ![]() Broomed off the ramp, nearly 5 gallon of clay powder/dust, very slippery. Road is wearing down bad! ![]() ![]() Soaked the roadway with water, sprinkle on the fines, soaked it some more, rebuild the surface to make it smooth. Lay down some asphalt to protect the surface. ![]() ![]() The fines pile grew a lot in the last week! ![]()
Now that is a lot of goodness, and hard work done. Really enjoy watching the progress a lot, and with new machines on the plant new challenges shows up. Heavy traffic can put some roads on a test for sure. hope you can adjust for a smooth haul road and get it where it needs to go. I could not resist to mess with one of your pictures.........a drone pix of your site....looks like so 1/1
Hope you don't mind i did this.......[IMG] ![]() Looking forward to vids....crunch crunch. |
Really nice work on the new truck Joe. I was curious how the dumping would work with the pup but now I see.
Thanks for the photo's Joe
You are getting some building done this winter... I would guess you powered up the trailer as well ? greg |
Did you just zoom the pic Bo? It does look moreso 1:1
![]() Thanx Tom. The dump area is almost too small for this combo. I do have a 2x25 Sabertooth in the trk & a power wire coming from the cab Greg to put power to the axles on the pup, don't really want to b/c cornering makes it act weird... I have some hubs with one-way roller clutches that I made up for the 8wd 4206 cross dump, but took them off b/c I discovered I sometimes needed 8wd in both directions with that rig. I can't make that alteration till I get my lathe working again... ordered belts from McMaster yesterday... the slow bus through customs. ![]()
Hey Joe.
I turned the pic. counterclockwise a bit to most of the revealing wall was gone, and cut out the footprints from the Giant..........lol Would love a similar pic. with your New awesome haul truck in there also......keep snapping picture plz. |
Came out great Joe looks awesome
Thanx Brandon, I like it too... get this rim slippage problem solved, then hammer down!
A vid showing the 963 leveling the fines pile, had to reload the vid b/c the original kept pausing for reasons I do not know ![]() https://www.youtube.com/watch?v=q_xf_I581ug
Crunch Crunch. The reload works good, So does the dozer.......and i said it before.....Excavator Operator Extraordinaire...... Now i gotta say Dozer Operator Extraordinaire.......Very nice work !
Joe-I agree with Bo-that is very nice dozer work. The herky-jerky stuff I see on here sometimes makes me crazy. You and dirtpusher (d-9 joe) as I call him are the best R/C dozer operators I have seen. Speaking of the D-9. Will it ever work again or is it worn out?
Well thanx Bo & Tom, much appreciated, I always try to put on a good show.
![]() ![]() The 1/10th scale D9 still has earth caked on it from the 2012 St Louis meet, D9 Joe kept the radio for it & I haven't turned it on since... it'll last longer this way. ![]() ![]() I asked Frank his advice what he uses for rim slippage, this stuff is the same (so I'm told by my autobody guy) as the pic he showed me. ![]() ![]() I thought I'd do my old B50 too, as I see rim slippage sometimes on the front axle when I try to back up a steep pile of lumps to start a new layer. ![]() ![]() ![]() Of course I couldn't help but wear some of it too ![]() ![]() I found a nail in one of the tires, how's that for scale detail? ![]() ![]() ![]()
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
