Old 07-08-2018, 10:35 PM
Default Re: LilGiantsConstrCo
Smoothed out west side Saturday morning
Used the B50 & pup to fill in the holes along the walls
Tonight I weighed out my cross dump train, the 1st try with plywood platform was doubled up & screwed together 3/8... not strong enough
Screwed a 3rd layer of 3/8... weight of platform is 38lbs
Loaded weight 219lbs (-38lbs)
Empty weight 137lbs (-38lbs)
Old 07-08-2018, 10:54 PM
Wow 82lbs of dirt!!! And the tractor with both trailers weigh 99lbs empty.
Are both trailers powered at the wheels?
Old 07-09-2018, 01:29 AM
Yes, brushed motor at each wheel, 12wd.
Old 07-09-2018, 07:41 PM
Watching your video I was wondering with all wheels being powered and as long as the combination is, do you have any kind of problem with the wheels on the last trailer when making a sharp turn as the radius is so much shorter than the other axles?
Old 07-10-2018, 02:24 PM
Last post on previous page shows a couple pics of the uni-directional needle roller clutches I installed in the hubs of last trl. A sharp turn, like near end of vid, last trl is on rudder ch, all the way right reverses motors so they will not engage - free roll. Lead trl is on throttle ch (I prefer to drive with my right thumb on elevator ch), I have to pull back on left stick a bit to keep from pushing rear of tractor sideways.
Whenever I turn at about 45 degree or less, it's at half speed, the motors aren't working at full power they tend to behave like an open differential to some extent & usually no added tx stick movement necessary. Both trl chs on Slave are mixed with tractor being Master.
Old 07-10-2018, 02:38 PM
Nearly finishing the 1st bench cut; I knew it was too high @17" with about a 2:1 slope, the hoe was 3" from the edge but it was always sinking a little as I reached out to fill the trls. Dozer time, new bench about 6" high will make loading much easier & SAFER! It'll be three more bench cuts to get down to the hardpan.
Got a nice blast rain this morning @8am, 2/10's in about 10 minutes, a welcome cool down after four days of 35C... I forgot to put down my eave extension last night ... got some dump trk hauling to do to fix the road
Old 07-10-2018, 06:08 PM
Wow, that cross dump is a beast!
Glad to see you've got some time to play again
Old 07-13-2018, 01:24 PM
Thanx frizzen, it has been an enjoyable couple of weeks in the shop, cross dumps have been working awesome, I like my redesign of the hopper doors on the 2nd trl, I think I will zip disc the doors off the 1st trl & make the same... after summer hauling.
Old 07-14-2018, 08:04 AM
Hey joe estimated time till job completion
Old 07-14-2018, 11:51 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Can't believe how smooth and flat you get the benches! More dozer videos please!
Jim
Old 07-14-2018, 08:05 PM
Jim
I agree jim, some blade skills,,
nice pics joe and the sorting sure makes for some nice material. hopefully before too long I get my screening project up and running. you don't get too much rock up there do ya, that crusher you have is that primarily used to break hard clumps?
Old 07-23-2018, 07:44 PM
Ah moving out the stock pile Mark? Try to get it all out before the white stuff comes again... I finished clearing that lil bench today, it's been so incredibly hot here last 2 wks with a few rainy days too, spend early mornings doing odd jobs on the farm, hide in the shop during the heat of the day & some nights an hr before dark hauling out or blading... get it done in moderation, don't wanna be too fast at it
Thanx Jim dirt is quite dry & grainy, easy to blade smooth compared to the rocky/lumpy dirt you tangle with in your videos... make yourself a screener & crusher like me & then you'll have nice dirt to work with too. That lil dirt pile took about an hr to smooth out, you'd probably be the only one patient enough to watch it all.
For sure Cooper, the screening & crushing activities add to the enjoyment value in keeping the equipment moving, Not a lot of rock?... I guess that depends on what you consider a lot of rock... in my soil I have everything from garden pea size/sand to watermelons.... not far from home I have some fields with rocks the size of Datsuns, when they get to sticking out of the ground too much, I then get the local TLB to either fish them out & skid 'em to the nearest rockpile or if they're too big to handle the op will dig a deeper hole to roll the rock into to get it a few feet below the surface, I likely won't see it again in my lifetime.
Everything from hardball & smaller rock goes thru the crusher, anything else larger gets hand picked & hauled away in my Ranger.
What's left for fines
Some rainy days in the last week, crushed some dirt lumps & rock
Got a big pile to put the thru crusher before winter
Old 07-23-2018, 08:34 PM
Rvjimd's Avatar
Ya, I would call that a big pile!
Jim
Old 07-24-2018, 04:42 AM
I'm glad to see there's a possibility for more videos coming on Youtube
Old 07-24-2018, 08:57 PM
Looks almost finished. Time to start hauling it all back inside again. Once it's filled in again, then you can dig er out again!
Old 08-16-2018, 05:01 PM
Skeeter, the back of shop is my holding area from winter digging, got get it empty so I can dig some more... finally nearing the end of the dirt piled up from the tunnel dig a few yrs ago (about 28 cubes)... finish the tunnel this winter, cutting in the steps & get back to digging the basement floor.
A lot of hot days in the last couple weeks, last week in the 40's... the dirt lump pile just about gone
East & west sides of shop are pretty to close to finished; now dumping on the north side, build up a sharp taper to the edge of trees.
https://www.youtube.com/watch?v=TXWs4jy6mzo
Old 08-16-2018, 05:37 PM
Rvjimd's Avatar
Joe,
You probably already answered these questions, but is your crusher just a typical jaw crusher and are you running dry dirt thru it? Any trouble with clay sticking to the jaws? How do you have it set? Pretty close? Looks close from the fines you make.
40! That is hot even me, a Fahrenheit guy, thinks that is hot! The only few I have memorized is 0-32, and 28-82 so 40 is HOT!
Jim
Old 08-30-2018, 12:28 PM
Nice work Joe-enjoying the videos as always.
Old 09-16-2018, 12:52 AM
Yes Jim, simple jaw, though I don't know exactly what the offset of the eccentric shaft iis. And yes, the drier the clay - the better it crushes. When screening the fines out & piling the lumps for a period of time again helps shorten drying... but there is some lumps with a bit of moisture within & it does build up near the top of the fixed jaw, I scrape with a wooden paint stir stick. The jaw opening is about 1/4... could go down as narrow as 1/8, but crush time could quadruple, depending on amount of rock quantity & size.
I don't know the conversion on Celsius vs Fahrenheit either... quick google tells me 42C = 107.6F... the hottest temps I've ever been in was during the early 90's of my harvester days, 117F; we circled back to NW Kansas in late July after they had 17" rain in 17 days, I spent more time outside slinging chains being stuck - then getting back into an ice cold cab... I caught the worst summer cold of my life to date!
That 40 heat wave caused a lot of crop damage this yr resulting in mega $ losses for what otherwise could of been a lottery yr.
Thanx Tom Majority harvest completed a few days ago, currently very wet outside, back in the Lil Giants workshop today tuning up digging equipment & headed for the basement here shortly to resume basement digging activities once again, haven't done any digging in nearly two years. Still have about 5 cubes of dirt to haul outside before winter in a few months.
Old 09-30-2018, 12:29 AM
Getting ready for the winter dig season
Swing motor had a bit of wobble in its mount plate
Added some blue locktite to the bolts & let dry before installing bolts
Not sure if I got a leak or if I'm just pushing the oil too hard making it weep every so little from somewhere... couple yrs ago I changed Jung pump from model# 4002 to 4003 increasing flow 30% to 1.8L/min, a definite improvement to move boom - stick - bucket simultaneously with good speed & no cavitation. Not touching pressure from where it was set with older pump, the pressure did go up to nearly 40Bar...
Lots of Q-tips & toilet paper, I got it pretty clean again. Can't see any notable leaks & have never had any significant volume drops in short periods of time the last yr.
Put it back together & it's off to the tunnel to finish digging out the walkway area... year #8 for the Beast If I were to guess the hrs, something close to 1600
