Old 07-08-2011, 11:14 AM
Default Re: CAT 14M Motor Grader
Great looking model! You are working really fast!
Old 07-09-2011, 03:49 AM
My trailer is slightly too short for the 14M
Old 07-09-2011, 11:51 AM
Car5858's Avatar
Car5858 Car5858 is offline
Sounds like an new project, extending the trailer.
That grader is a very nice work of art IMHO.
Old 07-09-2011, 12:08 PM
Pippoe Pippoe is offline
Pippoe is on a distinguished road
Thumbs up Re: CAT 14M Motor Grader
Another impressive build!
You guys really know your ways. WOW!!!
Great job.
Cheers
Pip
Old 08-14-2011, 02:30 AM
Hi guys, I´m finally able to get back to work with the grader after moving to a new house What a job that was it took a while to get my "machine shop" up and running.
First part I made was the front piece of the engine cover top.
Old 08-14-2011, 04:14 PM
It's great to see you back to making progress on this fine project Ari... patiently awaiting further updates with great interest.
Old 08-19-2011, 01:08 PM
I got the engine compartment bigger top piece done. The piece is curved half of it´s lenght, and I was not sure how it´s going to bend cause it´s 5 mm thick.
I did mill grooves in the underside in the area that should curve to help it bend.
Then I band saw a wood block to the same curvature and place the aluminium piece between them. Next I put it to a hydraulic press and press the wood blocks together (plate between), but as I release the pressure the plate returned straight Then I decided to heat the aluminium plate hot and did the pressing again. I left it under pressure to cool down, and this time it did stay in correct shape
Old 08-19-2011, 01:55 PM
You don't need to make two dies. All you need is one. Take a piece of soft rubber or urethane (you can get different hardiness) Place the part on the rubber then ram the die. The rubber will conform to the die pressing the metal. This may take some practice on what hardness rubber but the end result will leave no marks on the aluminum piece. I have a long urethane die I use on my press brake that I bend painted aluminum sheet on and the die leaves no marks.
Here's a picture I found on the web of what I was describing.
Old 08-19-2011, 02:08 PM
great work on the grader Ari, bravo on the heat
Old 08-19-2011, 03:56 PM
diddys trucking's Avatar
diddys trucking diddys trucking is offline
diddys trucking is on a distinguished road
STUNING JUST STUNING you are a model enginering god we are not worthy
Old 08-21-2011, 10:19 AM
I added some details to the engine cover
Old 08-28-2011, 06:15 AM
Some more details
Old 08-28-2011, 11:07 AM
D8R D8R is offline
Just getting better and better!
Dan
Old 08-28-2011, 11:13 AM
That is some incredible detail. Beautiful work!
Old 09-01-2011, 01:09 AM
Trucker47's Avatar
Dan
couldn't of said it better myself
Old 09-03-2011, 08:47 AM
Today I made the fuel tanks under the cab
Old 08-31-2011, 09:34 AM
smartcat smartcat is offline
smartcat is on a distinguished road
Yup.............. wow................ wow...........
Old 08-31-2011, 10:06 AM
androiduk androiduk is offline
androiduk is on a distinguished road
some it up in one much spoken word WOW
The day we stop learning is the day we die ! !
Old 09-03-2011, 12:24 PM
You have some grade A+ machine skills looking amazing
Old 09-10-2011, 12:25 PM
Today I started to make cab stairs
