Old 02-13-2014, 07:51 PM
So far this little piece has given me the most fits!!!! I'm not an engineer so I figure the mechanics of real machinery is working so use similar. I made this pivot block to where only one set screw will be needed and will be hidden. Gonna have to start thinking about hydros. Where do you guys get your bushings/ seals for piston rods and what size hose and fittings should I be getting? 1:14 scale.
Old 02-13-2014, 08:09 PM
Definitely have enough tilt!!!!
That's how far movement can happen before anything touches. I don't know how much tilt d11s have, maybe 15~20 degrees?? Going to start working on stabilizer arms
Old 02-15-2014, 01:37 PM
Old 02-17-2014, 04:36 PM
od jhon deer od jhon deer is offline
od jhon deer is on a distinguished road
Looking good so far I was just wondering what u used for track I did not notice if u said also did u get plans for it r just doing out of your head but keep it up
Old 02-18-2014, 11:03 PM
For the track pads I used 1/2 x 1" bar. For the links I (think) I used 3/8 x 5/8 and used a slitting saw to cut them in half for individual pieces. I'll try and get some pics of the stuff I used and how. As far as plans, yup all in my head after numerous times forgetting measurements I started writhing simple part sketches down for my lack of memory. I did get a cat parts/shop manual. The problem with the manual is you just get some non scale drawings but at least it's something to scale off of. And a bunch of pics of dozers from the web. I am trying to build a d11 but it has some blend of d9 also. A local cat dozer dealer is about three miles from home so I could see some machines firsthand. But they never get a d11 sitting around that is assembled. Too big and expensive, they usually go right to the job site.
Old 02-21-2014, 11:54 PM
Added a little of the detail.
Work on the side of the engine compartment and trying to blend into the front. Wanted to make the front sides a bit beefy for the blade hydraulics to attach to. Not sure how I'm going to accomplish that part, it's like cast into the side. Might mill a slot into,,,,well when I get there I'll be straining the brain again
I did re-do the roller wheels. Same internal size but made to look bigger. I think it make a big difference in appearance.
Old 02-22-2014, 10:06 PM
Working on the skid plate for front. Hats off to you metal workers!! Seems simple and easy but trying to transfer measurements from paper template to the actual metal shape is a bit of luck for me. Some minor tweeting but it will fit. I'm going to be bolting it to frame. Originally I was going to wrap it up the sides like the 1:1 dozers but a bit too complex for me
Old 02-23-2014, 07:08 PM
You did a fine job yourself.
What gauge is that?
Old 02-23-2014, 07:30 PM
A couple more in process,,,,
Lil giant, I'm working with 22guage, thin enough to burn through during welding very easy and thick enough to not be able to use hand shears. Just the right size to make it hard to work with (for me.
Old 02-25-2014, 12:21 AM
I think I'll have the skid plates done by weekend. Have to weld two pieces yet. But this is what I've come up with so far. I have a 2-56 broken tap in one of those holes and I over tightened a brass 2-56 screw trying to get the metal to lay a little more flat and twisted the head off. More work!! I'm going to mill out the tap and drill out the brass then I'm going to try that aluma-weld stuff. If that does the job I'll be able to re drill and tap new holes. It just adds more time and the p.i.t.a. Aspect. . Have some materials for hydraulics coming later in week, so I guess I'll be needing to get valves and pump soon. I think the pump and valves will be the bullet-biting expense. Once I get my fingers on one I'll try and make my own for other projects.
Old 02-25-2014, 08:46 PM
Figured I will need to have rotational movement if I plan to have a tilting blade. I will be using stainless with a setscrew as a retainer for the pivot shaft.
Old 02-25-2014, 10:15 PM
Here's one for you lil'giants, I saw you recently got a "smart" phone ,, lol, actually once I figured out how to make a simple call all was good. There are some very useful apps, this one comes in handy a lot!! And it is surprisingly accurate. More than I can use a sight level. But it did take me an hour or so trying to figure out how to switch all the views
Old 02-26-2014, 10:58 PM
I figured this was the easiest way for a chain adjuster/tensioner. It's simply a idler, a flanged bearing, with an offset center that I can set the free play. As I didn't think a spring tensioner would work on account of both forward and reverse tension applies. In the pic you can see by the first one the top chain is curved. And the bottom pic with the tensioner adjusted the top chain is straight from sprocket to sprocket, and that is forward rotation to where more pressure (should) be applied by pushing a load.
And a pic of the part, I'll be using a tooth washer for some more security of keeping it in position.
Old 02-26-2014, 11:07 PM
And if I show the good I guess I have to show the bad. I broke a 2-56 tap off in one hole and spun the head off a brass 2-56 bolt. So I decided to mill out the broken and use that aluminum weld stick stuff. I watched some tube videos and tried it. Well the vids make it look fast, I heated and heated with mapp gas. Well I just missed that magical temp as by the time I was done fixing the holes I had a big drooping bulge of liquid aluminum on the bottom. Well once I learned how to use it the second part was pretty easy. That stuff comes in handy. But now even though I was using it to fix a part and save some machine time by not having to remake the part I think I will anyway.
First try.
Second part, top hole was the one remade.
Old 02-27-2014, 09:03 PM
Thank you Cooper for the tip on the phone app, I'll look at doing the same for my phone too.
And the set up pics of machined parts, I'd be interested in seeing more of them too. My knowledge of machining & how to do it safe & accurately is very limited. I've just got a mini mill right now in my house, never did anything too complicated with it b/c of its lack of rigidity. But my soon to be finished garage will be getting a bigger one this fall, probably one like yours & I'll look forward to do more of my own machining. And tips on accessories you use during your build would be a plus as well, plz.
Old 02-28-2014, 08:35 AM
Will include some more of the machining pics. I can't say I know what I'm doing as these are scratch builds from air plans but I always figure there is a way for something to be done. Ya know that old saying if there's a will there's a way, well s few scrap parts and some broken tools later , yes there is. Lol,,,,
Have some more work to do but a pic of the skid plates. One front and one back. Both bolted on. I had to file a housing support on the motor gear housing down some but other than that it a pretty snug fit. At least keeping some debris out.
And a side shot, starting to figure out operator housing and stabilizer bar.
Old 02-28-2014, 01:14 PM
Nice work!
Where will the hydraulics fit?? lol!
Old 02-28-2014, 06:39 PM
Originally Posted by Azonic View Post
Nice work!
Lol, yes the motors fill up quite a bit of space. I might be thankful that I'm making a blacked out cab, I may need that area for electronics. In a serious note I have not handled any of these pumps or valve blocks but by seeing them on the forum and for sale sites I do think things will be crowded. 5 valves (independent tilt cylinders) sabertooth esc, (forget but about 4" wide) lipo batteries, sound module , speaker, thinking about a computer fan in front grill for added cooling, and hydro pump with motor attached.
After reading what I just wrote it does sound like it will be crowded!! I think its time to order pump and valves before placement of those parts. Might be a bit of puzzle. .
Old 02-28-2014, 07:28 PM
How much space do you have in front of the motors ? It looks like you may be able to put the jung set up Fumotec uses . This is where I placed mine on my TD 40 and plan to put a fan on the back side of the pump motor (outrunner )
Old 02-28-2014, 06:13 PM
titandigs's Avatar
Aussie Fabricator
Hey Cooper,
What's the name of the APP? I downloaded tilt meter but it's different to your screen shot.
