Old 11-12-2016, 07:34 PM
Post a pic of the bed next to my d11
Thats cat# 458-9587
Old 11-12-2016, 07:42 PM
I didn't want to touch the bed and sure didn't want to pick the dozer up next to it!!!
Light is casting a shadow onto both of them and the tank only has one coat on it but you can see the difference in old cat yellow (tank) and new cat yellow (dozer can)
Old 11-12-2016, 07:46 PM
Joe, finally got to pump, this is the number on it.
Old 11-12-2016, 09:03 PM
That's not it, that # would be Martin Kampshoff's stamp. The # I refer to is the # stamped right on the pump just above S P, it's sometimes very faint to see. The # on both these pumps is 4002 which is 0,30ml/revolution
Old 11-12-2016, 09:12 PM
Here is a suggestion to improve flow to your dump cyls, use 4mm fittings on the valve to a tee block, then 2,5mm fittings from tee to cyls. The 4mm fittings on valve need to be filed down to screw into place, just leave enough flat spot to snug with a wrench.
Old 11-13-2016, 10:55 AM
Originally Posted by ihbuilder View Post
OK when did they change they're yellow again I notice 2 shades at Cat Monday but didn't think to ask .
Originally Caterpillars were painted Gray up to the end of 1931 Then changed to "Hi-Way Yellow" December 1931 making them more visible on construction jobs.
Cat changed the old "Hi-Way Yellow" to the new present day gloss yellow between 1979-1984.
Main reason for was the old yellow had a high lead content which is now banned. The old paint lasted longer because of the lead though. I have restored several old Cats from the 30's that still retained the gray or yellow paint.
Old 11-14-2016, 12:04 PM
First coat on the frame.
Joe the number on pump is 4002. Now that I have everything apart I'm going to open things up a bit try and make bigger hose work and open up the fittings some. I'm feeding both those big cylinders with one valve and 4mm hose. Doesn't make much difference if I up the rpm on pump so I'm pretty sure it's a restriction issue with all the small fittings and hose. Thanks joe.
Old 11-14-2016, 12:14 PM
Thats a few cans of yellow right there
Old 11-14-2016, 02:16 PM
What's the pressure set to? Higher pressure will dramatically increase flow... 250psi would be bout right.
Old 11-14-2016, 06:38 PM
Looking at the gauge now I think I was only running 100-125 psi, around 10 bar. So plenty of room to up the pressure,,,
Old 11-14-2016, 06:44 PM
Swapping out one of the 4:1 planets for a 3:1, increasing speed some. Trying to get up to 30 mph (1:1 scale) speed. Forget if I ever greased the other two planet gears, well it's apart so might as well clean and regrease. So I should end up with tranny being 3:1,3:1,4:1 then diff being 3:1 gearing reduction.
Old 11-14-2016, 06:54 PM
Here is the gearbox taken apart still have 5 of the 3:1 planer gears inside the ring gear yet , but you can see the size. Couple of you asked about gearbox, banebots is where I got it from , it is the p80 size
Old 11-15-2016, 10:05 AM
Hofabooz's Avatar
Hofabooz Hofabooz is offline
Well what can i say this post is amazing I have just read from beginning to end over the last few days.
Very high level of work and quality. You shouldbe proud of your work.
many thanks for sharing this with us all.
Regards
Mark
Over the Pond in the UK
Old 11-15-2016, 10:27 AM
mark
read his D11 build too
http://www.rctruckandconstruction.co...ead.php?t=7861
Old 11-15-2016, 10:32 AM
Hofabooz's Avatar
Hi Bigford
Will do.
Thanks for the pointer.
Regards
Mark Over the pond in the UK
Old 11-15-2016, 05:27 PM
Efroeh Efroeh is offline
do you use any drawing programs 2d or 3d or whatever for when your building your projects? or just by hand?
Old 11-15-2016, 05:32 PM
his plans,drawings and everything
http://www.ebay.com/itm/NORSCOT-CAT-...YAAOSwnbZYHlBw
http://www.ebay.com/itm/Norscot-5521...gAAOSw8w1X2HMn
Old 11-15-2016, 07:00 PM
Yup that pretty much is it, for the d11 and haul truck I did also purchase (off eBay) a shop manual. It shows some parts to get better idea of how they fit and work. My plans are just number jotted down on a notepad and some rudimentary hand sketches. But I have it all thought out in my head . Lol!! That's why I end up with a few extra parts, ya know cut it twice and it's still short!!
Old 11-15-2016, 09:32 PM
That's a great idea I seen the model toy but the shop manual would be really helpful. Can't wait to see it once it's all together.
Old 11-16-2016, 01:23 PM
All parts painted with exception of having to hand paint railings. I didn't want to take them off as I might not get them back on.
And haven't seen this for a while!! Cleaned off and now ready to build her back up!! I did order some bigger smc fittings and need to make a splitter but no big deal for that. I went right to the source,
Smcpneumatics.com
Is the site that manufactures all the push to connect fittings. Cheaper to order from them and quicker than waiting for some from overseas. The site has all of them but you may have to go to the online catalog and find the part reference number because the pictures don't always match the part. I'll try and post this in the reference section for others also. Along with banebots.com for planetary gearboxes.
