Old 03-30-2017, 12:28 PM
arh1a arh1a is offline
arh1a is on a distinguished road
Default 4200XL v1.5 - Pressure Gauge Fitting
Hi all,
I want to fit a pressure gauge to my 4200XL to keep an eye on the hydraulic pressure and also check that is it running the 20bar it should be.
Firstly is where to buy a suitable one from that will fit and ideally from the UK if possible? Also might need to know where to get some more hydraulic line and fittings.
Secondly is does anyone have any photos of one fitted to a 4200XL as I want it to be an neat install as I want to fit it permanently.
Many thanks in advance.
Old 03-30-2017, 02:42 PM
Default Re: 4200XL v1.5 - Pressure Gauge Fitting
Premacon.com would have everything you need.
Whether you placed the tee fitting between pump and valve or valve and prv would work fine. With a bit of length from tee to the gauge, you could place gauge wherever you want inside body.
