Old 02-10-2015, 02:41 AM
AWR13 AWR13 is offline
Location: Germany, near Freiburg (in the south at the Swiss border)
AWR13 is on a distinguished road
Default Sound needed
Hello folks,
now i need your help.
For my actual projekt i need a engine sound. It should be used for the Peterbild 351/281. So I need a sound without turbo. It is not necessary that the sound is from this truck, it should only sound similar.
The problem is, that i need a lot of different and good sounds. I need this:
The following soundsections are necessary:
1. Engine start up
2. Engine idel
3. Reeving up the engine
4. Accelerate
5. CONSTANT low speed in 1st gear
6. Further acceleration and switching to second gear
7. CONSTANT low speed in 2nd gear
8. Slow down and stop
9. Engine shut down
Does anyone has someting ? In Germany it is impossible to find someone with such a truck or engine for recordings.
Many Thanks
Andreas
Old 02-12-2015, 01:24 PM
Stuart's Avatar
Stuart Stuart is offline
Default Re: Sound needed
I would recommend a beier usm rc2
I have 2 of these and they work great, take a bit of setting up on the computer to work how you want them to though.
1 is in my JD9530
the other is in my 944B
you can copy a sound from youtube and edit it to suit your needs, also if you email beier they will create a sound file for you.
Surprised you havn't come across them already as they are German!
Hope this helps
Stu
Old 02-12-2015, 03:08 PM
Hi Stuart,
you are right, but i have only very small space. So i want to use the Benedini "Soundmodul TBS Micro V2.0 " And Benedini has not the corectly soundfile. Click
Andreas
Old 02-12-2015, 09:24 PM
Supermario's Avatar
Originally Posted by AWR13 View Post
Hi Stuart,
Andreas
Thank you for sharing the link Andreas. I don't mean to high jack your thread but this is the first I've heard of the Benedini system and the sound file for a 345 excavator is absolutely amazing and accurate! Looks like a great product.
http://youtu.be/20e3yMWz6tA
