Old 09-01-2016, 11:06 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Ny-Lint Mobile Dragline Conversion
Here is a little video making a five hole bolt circle in one of the boom pulleys on the crane.
http://youtu.be/pHBZeMw3kIU
Jim
Old 09-01-2016, 10:13 PM
That's a really cool manual mill setup!
Old 09-02-2016, 07:26 PM
modelman modelman is offline
Interesting video jim-I don't have the digital readouts but I can do the same thing with a rotary table. Your way looks more complicated to me. Do you think there is an advantage in using your method?
Old 09-02-2016, 07:47 PM
Rvjimd's Avatar
Tom,
I have a 3 jaw mounted on my RT so the weight is at or above my ability to safely move it to and from the mill table and most of the time I have the vise mounted so that save me from the change out.
Here is something I learned from watching one of tom liptons videos of a similar topic-
For a bolt circle on a rotary table, the larger the diameter the more potential error introduced if the angle is not perfect. On the DRO, it wouldn't make any difference how large the circle was.
Another way to think about this comes from aircraft VOR navigation. At a radius of 60 miles from the transmitter station, a one degree deviation would put you off course by one mile. That would be a really large bolt circle, so probably not a concern.
Keep in mind that I only pretend to know much about this stuff!
Jim
Old 09-03-2016, 01:16 AM
doodlebug's Avatar
Jim
Thanks Jim, had no idea on what all a DRO will do!
Cheers, Neil.
Old 12-17-2016, 04:20 AM
It's probably too late to help, but the unknown yellow machine pic you were modeling the new tracks on is a John Deere 690 / 690a
http://www.yesterdaystractors.com/cg...wlers&th=94405
Old 01-19-2017, 05:20 AM
Sorry to keep cluttering your thread up, I couldn't tell from pics.. Did you put the swing servo at the back of the house below the drums, or where the operator would sit?
If it's operator seat, still have room for a figure? If it's under the drums, hom much worse is maintenance?
Old 01-19-2017, 06:25 AM
Rvjimd's Avatar
No problem with clutter, you should see my shop right now!
My operator sits directly on the swing servo. The height worked out pretty good.
Jim
