Old 03-26-2015, 10:24 PM
RM model Mack RM model Mack is offline
RM model Mack is on a distinguished road
Default Re: Prototype Cat Tractor and Road Groomer
oops
Old 03-26-2015, 10:31 PM
Awesome idea! I do have a tank/pump setup from an abandoned tracked brush fire vehicle project and will try to retrofit them.
On a side note...
The XL 2.2 tires have created some issues in the form of...
1. inner tire rub on the leaf springs at full steering lock (even at 55% EPA)
2. too tall gearing. The disruptor trans has the smallest pinion in it, so no further reduction options available
so here it is on 1.9 mud bashers. These slow the tractor down a lot and eliminate rubbing even at 120% EPA. Looks more scale now too I think but I'm open to opinions (1.9 vs 2.2)
Old 03-26-2015, 10:37 PM
Lmackattack's Avatar
I think the small tires look just as good. The real test will be what tires give better traction for when it's grooming? I suspect the smaller tires would. as far as gearing. What turn motor is in it. You might go to a higher turn to slow it down?
MACK
"The Greatest Name in Trucks"
Old 03-26-2015, 11:03 PM
Ok good to hear. Will stick to 1.9's for now and do some 1.9/2.2 comparison testing as soon as it dries out. Lots of rain in NJ today.
Its a 35 turn motor. I have a 55 and will try it.
Old 03-29-2015, 08:36 AM
Painted land leveler implement and the 1.9 wheels. Also added a fuel tank
Old 04-12-2015, 10:40 PM
Did some testing in the backyard test facility today.
The 1.9's sunk and dug in immediately so went back to 2.2's. These solved the traction issue and the gearing is OK.
Some videos of the first runs...
https://www.youtube.com/watch?v=pk7sHrLft6M
This design seems to do a better job in the loose stuff (paver base)...
https://www.youtube.com/watch?v=yWDPGXH2aS4
Old 04-13-2015, 01:58 PM
kroll62's Avatar
kroll62 kroll62 is offline
kroll62 is on a distinguished road
It looks like it runs pretty well. The implements you made work nicely too. Great work. Do you have any other implements planned or in the works
Old 04-13-2015, 10:07 PM
Thanks Kroll.
I would like to try a 4 or 6 bottom plow and perhaps a harrow like this one from bruder:
Old 04-15-2015, 01:02 PM
NYHowie NYHowie is offline
NYHowie is on a distinguished road
Appears to work quite well. Great job, awesome build.
Old 04-17-2015, 04:56 AM
Thanks.
Making some adjustments and trying again soon with a better radio system and at a larger area (a baseball field).
Will post it up after.
