Old 08-10-2014, 10:36 PM
Gmny803 Gmny803 is offline
Gmny803 is on a distinguished road
Default first build blues
I want to do a tracked Jd tractor for my first build. I'm having a tough time trying to figure out what type of drive motors to use. I want to do a geared motor direct drive Any help would be greatly appreciated so far as what to buy and where to buy. Im in the states. Also a brief list of electronic parts needed would be awesome. Thanks in advance
Old 08-11-2014, 11:51 AM
Acadieman Acadieman is offline
Acadieman is on a distinguished road
Default Re: first build blues
It can be daunting to begin, but keep at it.
I bought my motors and electronic speed control (ESC) from Fingertech Technologies as they were smaller and a better fit for my project. Since your tractor is bigger, you may be able to handle the stronger RB 35 type motors.
Here are the website I browse for motors and other gear:
http://www.servocity.com/
http://www.robotshop.com/
Servocity has a few new models out, and they supply parts to RobotShop.
I am unsure what people are using for ESC when paired to the gear motors. Robotshop has a few controllers that would be worth checking out. Aside from the ESC, you may need to find a proper battery eliminator circuit (BEC), a receiver/transmitter, and a servo for the 3pt hitch if you desire. Since its a track drive, you would actually need 2 ESC so you can control the speed of each motor to be able to steer.
Some people use continuous rotation servos. They seem to work great, and require less space. ESC are not needed. If you go with 2 servos, you would need a receiver/transmitter, a BEC, and a 3rd servo for the 3 point hitch if your going to bother.
Old 08-11-2014, 06:06 PM
Thanks for the advice. I truly appreciate it
Old 08-12-2014, 08:48 AM
This might be a good thread for you to follow:
http://www.rctruckandconstruction.co...ead.php?t=9182
There are others like it as well.
Old 08-12-2014, 08:51 AM
Grainfarmer Grainfarmer is offline
Grainfarmer is on a distinguished road
Maybe you find some here ("RB35 type")
http://mfz-blocher.de/getriebemotoren.html
regards,
Frank
Old 08-13-2014, 12:47 AM
rc_farmer's Avatar
Master Builder
Hope this helps, le'me know if can help
http://rctruckandconstruction.com/showthread.php?t=3512
Giving up is not an option!!!
Rob
Old 08-13-2014, 01:29 AM
Thanks i truly appreciate the help and warm welcome.
Old 09-09-2014, 03:30 PM
I have two motors that draw 120ma at no load how much battery would I need for about and hour of running
Old 01-21-2015, 10:28 PM
Progress
File Type: jpg 20141215_103326.jpg (157 Bytes, 143 views)
