Old 04-18-2014, 06:47 PM
Angry It was going good until...
Well the weather was very nice today, no wind, no humidity, and about 71 degrees. Perfect painting weather. So I decided to paint the fenders on the "SLUMLORD" and trailer. Started to lay down the paint, and everything went well. I got done came inside waiting a little over an hour before bringing the fenders in. I went to get them, and from a distance they looked pretty good. Up on closer inspection I got Very PO'd. A bird decided to use two of the fenders for a toilet. One fender the mess came off without ruining the paint, but the other you can see where mr. bird droppings were. So now repaint, just another thing to slow me down getting done for Indy. But this will not beat me, I will win.
Old 04-20-2014, 10:32 AM
rc_farmer's Avatar
Master Builder
Default Re: It was going good until...
John, i know it aint funny, but if it aint the birds, its the GNATS!
Giving up is not an option!!!
Rob
Old 04-20-2014, 06:16 PM
Well Rob, I can laugh about it now. And you are right, gnats are an issue, but right now I haven't had any to bother me...but it is early in the season though. I sprayed my Scania roof again, and just as soon as I was done, I brought it in. No more poo...
Old 11-17-2014, 09:51 PM
Joe25's Avatar
Joe25 Joe25 is offline
Joe25 is on a distinguished road
Fwiw, I had this problem quite a bit when I built static models. And its frustrating as ****
My solution: I made an acrylic box 4'(L) x 4'(W) x 2'(H) (1.2192m x 1.2192m x 0.6096m) with 1 3/4" (4.445cm)
holes drilled in top & sides with 3" (7.62cm) disks mounted 1/8" (0.3175cm) outside the holes.
But there's the problem of gnats which I didn't have (live in a desert) but I bet you could tape some of the paper coffee filters to the inside of the openings it would probably work... just an idea
Top makes a good work area if ya lay a board over it and side can be customized for hand tool storage with the clips for hanging a rake on the wall too
Make peace or Die! 1st Bn 5th Marines
Old 11-18-2014, 08:43 PM
Thank you Joe25, I may build something, but I would like to be able to fold it up when I was done for the day or take it a part. I should be able to figure something out.
Old 11-18-2014, 09:46 PM
Joe25's Avatar
Couple piano hinges should suffice there, rubber gasket along top with a latch... and please Joe is fine
