Truck Building Tech Covers mechanical and electrical components for truck modeling |
How do you route trailer lighting wires?
First time building a Tamiya trailer. I have the light kit for the 3 axle reefer trailer. After the wires pass through the front wall of the trailer, what is the best path to route them to the rear bumper? Doesn't seem that they should be visible inside the trailer.
Re: How do you route trailer lighting wires?
When you run the wires for your lights, there will be supports between the plastic piece for the interior floor and the metal piece that mounts to the frame. The supports will have the center opened so you can run your wires, and out the hole in the bottom piece to your light housings. Simply mount the interior floor after you run the wires with double sided tape, which is included in the light kit, and your wires will be hidden.
Hope this helps, Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
Big John.
Thanks so much. There are times when the Tamiya instructions leave somethings to the imagination. |
From front to back.
I missed one thing and Travis is on it like a tick on a blood hound. Just picking on you Travis, it's all good.
