Old 04-30-2016, 05:18 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Location: Mount Evelyn/Lilydale Area, Melbourne, Victoria, Australia, 3796
Kingcam2 is on a distinguished road
Default Servo Problem
Hi everyone,
I need help with a servo or a valve bank problem on My Rc Kat excavator?
At first I though valve has seized but after pulling the servo off and opening the valve then valve turn fine, I am now thinking the servo is sick or weak?
Regards Cam,
update:
Turn out the servo is the problem it gone weak, my next question is
What servo do you guy recommend replacing it with?
the old servo is a tower pro MG995.
Regards Cameron.
Sees no evil, Hears no evil, Speaks no evil
Old 04-30-2016, 10:11 AM
bigford's Avatar
bigford bigford is offline
Default Re: Servo Problem
cam
those tower pro's gave me nothing but trouble with my kat
I went with these and no more problems Hitec HS-85MG Premium Metal
Gear Micro Servo. but I changed to a more power valve body. stock valvebody
was leaking.
you need a standard size servo with the stock kat valvebody
Old 05-02-2016, 12:41 AM
Kingcam2's Avatar
hey guys, little update on this, Turns out that there was nothering wrong with the servo on my valve bank, all the rubbers in the valve bank had dry up and was causing the valve bank not to turn freely, so I pulled it all apart and clean everything and oil everything and put it all back together and she working fine now
