Old 07-04-2017, 03:36 PM
honda3 honda3 is offline
honda3 is on a distinguished road
Default channel mixing
Hey guys is it possible to mix the pump with channels with the stock radio on my RC4WD 360L? Just wanted to make sure before I figure out how. Also, what exactly are the pros and cons of doing this other than the pump not running continuously? Thanks guys
Old 07-05-2017, 01:56 PM
Default Re: channel mixing
If you mix it to the point where the pump only turns on when you move a valve, it's going to put a lot of strain on the speed control to start/stop the pump.
Pros is that the hydraulic fluid does not heat up when the pump is not on.
Old 11-14-2017, 12:27 PM
lenny lenny is offline
lenny is on a distinguished road
just wanting to know if the stock radio for the 870k front loader, the fly sky fs16s can have more then one mix set up. Trying to mix all hydro valves to pump speed. Not sure if you can or not. I have already mixed steering with pump but would also like the rest to be mixed so the pump isn't at full speed all the time. thanks in advance Lenny
Old 11-14-2017, 01:42 PM
Efroeh Efroeh is offline
Any info oh how you did this?
Old 11-14-2017, 03:43 PM
Northern Farmer's Avatar
Contact Diggingwithmartin on youtube leave him a comment. I’m sure he could help you out.
Old 11-14-2017, 05:42 PM
Just another thought, my Magom wheel loader has all functions mixed to have the pump come on or you can just turn on the pump via TX. I've found that with the pump always running I get better response than when it only comes on for a function.
Old 11-14-2017, 06:34 PM
I was only asking due to the pump being just as loud as the sound system. the battery run time is not really a major problem, just thought it would be better for indoor use to quiet the pump some. But it is true pump running off the tx does give better stick response. Seems I can only set one mix thru the radio. If i try and do another it wipes out the first mix. Pump is set to 30% on end points now so not as loud but still hardly quiet.. thanks again Lenny
