Old 07-16-2017, 11:23 AM
Default what is the temperature at he hydraulic pump?
With a temperature probe, what is the temperature on the hydraulic pump? Does not matter of make. Just after a good amount of use. Im curious at what temperature others are at. I'm seeing up to 48c.
Old 07-16-2017, 06:43 PM
Default Re: what is the temperature at he hydraulic pump?
I don't have a probe, mine are always just warm to the touch after a batt or two. I'm never outside in the sun with them.
Old 07-31-2017, 08:30 PM
doodlebug's Avatar
Keep the oil under 160 degree Fahrenheit , and you'll be fine!
Cheers!
Old 08-01-2017, 08:26 PM
Colin11123 Colin11123 is offline
Colin11123 is on a distinguished road
The ShellTellus 15 I use doesn't start to break down till fairly high temp, should be fine up to at least 65—70°C in the longterm, with an absolute Max of 115°c higher than that and it will lose its lubricating properties
