Old 10-08-2017, 12:49 AM
Nuttz Nuttz is offline
Nuttz is on a distinguished road
Default Dozer conntrol question
Hey guys just after some help wwith my rc4wd dozer using the radio link at9 wanting to reasign channels five and six to the right stick on the radio(blade up and down and tilt left and right then using a switch tto swap to riper control anyone know iif its possible on this radio or point me in the direction of one the can do it thanks
Old 10-08-2017, 04:01 AM
Northern Farmer's Avatar
Default Re: Dozer conntrol question
Contact trucker1970 on here or his youtube channel Frank Smith. He has the same dozer as you and changed his radio for something better
Old 10-09-2017, 04:56 AM
Thanks mate ill have a look.
Old 10-21-2017, 06:43 PM
Cool Re: Dozer conntrol question
https://youtu.be/oxGPnQMmqpI
Old 10-22-2017, 10:52 PM
Using the stock TX here are some screen shots of the mixing I was given from a fellow in AUS. I still had to switch the motor esc's in the RX to work correctly and reverse a channel or 2. You may not. Sorry for the fuzzy stills. Main thing to check are that the Mix 1 and 2 are "on" in the upper right of the screen. I reassigned the ripper to toggle buttons "E" and "G" on the TX. Also if you go this route your TX will now have a blinking red light next to the solid green light of TX power. No worries, this is just an indication that a channel mix is active.
Old 10-25-2017, 01:40 AM
Thanks mate ill give it a try it is a bit different to how i had it first so probably will work better ha.
Old 11-01-2017, 12:50 AM
Any word? Got it rolling as you'd like?
Old 11-01-2017, 01:58 AM
Not yet mate have been busy hoping to get to it this weekend ill post up some pics when i do .
