Fire and Rescue and Emergency Vehicles Here is a spot for all them important emergency vehicle builds. |
holms 450
do I do a build thread or just post when it is all done
Re: holms 450
build thread if you took a lot of pic!!
Re: holms 450
We like build threads with lots of pictures. A lot of the newer guys on the forum just like to just yac about their builds. We like to look at pictures!
Re: holms 450
ok I will be starting to assemble the wrecker booms and all the pulley system next week will start to post then
but just so you guys know this thing is huge I decided on mad force axels, Tamiya three speed, kyosho chain drive transfer case ,steal drive shafts, 1/4 x 1/4 steal frame rails ,aluminum 4 bars ,dual rear wheels ,all steal twin booms, 4 winches on the wrecker deck this is the old school 450 all cables no hydraulics. still then the body going to try for a 50's r 120 corn binder. but may go to lf 120 freightliner single axel . |
Re: holms 450
Can't wait to see your build. I used to drive a mid 70's 50 series Chevy with a 550 Holmes on it "back in the day."
Re: holms 450
i'm not sure what kind of holms we had. it had two hand crank
boom lifts and one winch. it was mounted on a 88 gmc 6500 |
Re: holms 450
when I was a kid my father was a partner in a towing company. I will always remember him gone from home 7 weeks to build his LW Kenworth wrecker. way before rotators and HYD
Re: holms 450
The 550 I drove had two hand crank boom lifts and two winches. You could pull a pin and split the booms and work straight out each side of the truck if needed. Did some pretty wild recoveries for a smaller truck.
Re: holms 450
ok so here we go not gonna tell you what body but I got started. first off a couple of shots of what the **** I am trying for
so now we are all on the same page the frame I started with transfer case (comes from Kyosho) Misc parts you all know what this is axel also Kyosho not sure on the leaf springs I think not I am alloy further but no ready for next pics |
Re: holms 450
moving on
parts for the pulley system on one boom the pieces make these the boom pieces I was going to use these wheels ant tires now new idea just need parts of the rim had to do 4 rims tor this truck had to remove the outer ring and trim off the lip |
Re: holms 450
so then had to cut the center out of this rim
test fit the two pieces there is a big gap need to do something cut a bunch of scrap lamicoid stack up 4 pieces attach the stacks to the rim test fit all good attach the inner to the outer rim ______________________________________ repeat for the other three rims now back to the deck here is the back stop that all the booms attach to the sling the winches the boom swivel pivot thing ---------------------------------- the pulley end of the boom |
Re: holms 450
tossed the frame and built a new on also went to leafs in the rear
Re: holms 450
I love those Wreckers
all the DEDICATED Members will be there. the hobbiest formally known as Sweet Pete Wrecker, Founding Member of the East Coast Mini Truckers. |
Re: holms 450
so here s a little update
oh yea it is in the new 1875 square inch shop now |
