Smoke systems?
Does anyone have suggestions for adding a smoke system to one of my trucks? I found this one for drift cars called the burnout demon and it looks like it might be adapted to route the smoke up thru the stacks. Any thoughts?
http://driftmission.com/burnout-demo...oke-generator/ |
Re: Smoke systems?
Re: Smoke systems?
Us tank guys have had good results with the Tarr units. If wired through an ESC the fan is proportional to your throttle. You have 2 inputs, one for element power and one for fan power (which you'd tap into your ESC or off the motor.)
http://www.rctankelectronics.com/sto...moke_Unit.html Last edited by TheBennyB; 09-24-2016 at 01:16 AM. |
Re: Smoke systems?
build your own
http://www.scale4x4rc.org/forums/showthread.php?t=25024 |
Re: Smoke systems?
I don't need oil residue on my rigs or anyone else's pass
Re: Smoke systems?
I have thought of experimenting with an electronic cigarette and some kind of a fan. They have some called "drippers", very simple and put out a lot of vapor. The liquid for the ecig can be purchased without nicotine and almost any flavor imaginable..... plus when you get an itch you can just take a drag off of your stacks! lol
Re: Smoke systems?
The boat guys use a water vapor system but there
Kinda large. Our problem is the tranny lines up with the stacks. |
Re: Smoke systems?
Hey mister, Why does your truck smell like candy? With the glycol foggers like the vape people use, would the a plain glycol base make your smoke smell like a coolant system leak?
You might be able to run one of the small fountain 'ultrasonic foggers' that just use water. Stick it in a small sealed water box that you plumb to the stacks. Not sure it they make lower voltage that 24dc, this was the first i found . https://www.amazon.com/Etree-Ultraso.../dp/B0067XS2IG |
Re: Smoke systems?
The boat ones look like the driftmission one but use water not oils. I always say black power white water
I run a factory c15 625hp cat and don't blow any smoke.... |
Re: Smoke systems?
-Jeff To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thread Tools | |
Display Modes | |
