Old 02-18-2018, 09:01 PM
code3pse code3pse is offline
code3pse is on a distinguished road
Default Two esc in receiver.
Hello. I need help. I will plug two esc for two motor application in my loader. I will drive my hydraulic pump and the transmission. Could you give my the wiring diagram for plugging with only one battery? Thanks.
Old 02-19-2018, 10:35 AM
bigford's Avatar
bigford bigford is offline
Default Re: Two esc in receiver.
You need to join the power wires together red to red black to black. Then disconnect one red servo wire from
The esc plug. I would make the esc with the red wire still connected the motor esc and the other for the pump
Old 02-20-2018, 05:41 AM
Google busbars
Power & + - loops on one side; connect all your esc's & what not on the other side.
The esc that has the highest BEC (battery eliminator circuit - powers your receiver), use that one & disconnect the red wire from the receiver plug on the other one. Having both providing BEC can lead to radio glitch interference problems.
busbar in white
Old 02-24-2018, 05:24 PM
Thank you very much for the tips!
