Old 09-23-2017, 03:43 PM
tractorman tractorman is offline
tractorman is on a distinguished road
Question Eagle machinery 8x8 truck fault need help
Hi i have a friends 8x8 truck and its not 12 months old new battery fitted to truck tranny charged and the whole thing refuses to move or make a sound flysky radio Etc green light on one esc the other for the tipper flashing red the main drive esc is very hot, ued a servo checker on the steering works ok.
Any ideas ?
Old 09-23-2017, 04:07 PM
Colin11123 Colin11123 is offline
Colin11123 is on a distinguished road
Default Re: Eagle machinery 8x8 truck fault need help
Try are calibrating the ESC may just have lost its end points
Old 09-24-2017, 02:39 PM
Thanks i will give that a try, there are 2 different makes of esc i will have to find out how to do each one , one is brushless the other is brushed.
Old 09-25-2017, 03:59 PM
scottyk scottyk is offline
scottyk is on a distinguished road
If the esc is hot that means you have some current flowing thru the system. Theres no sound at all when you plug in the battery? I believe there should be a series a musical beeps indicating it is on, then a series of consistent beeps indicating how many cells the lipo battery is.
Id be wondering what is drawing enough current to make the esc hot while nothing is happening, maybe a locked up drivetrain and a shorted out drive motor or something similar? If you fried a esc that might be the one supplying the RX with voltage via BEC circuit, which means nothing will work at all if the RX doesnt have any power. With that being said, also check to make sure the TX is bound to the RX
Old 09-25-2017, 08:18 PM
Pull the hot esc off the rx and see if the rest of it works.
Kinda sounds like both esc had its internal bec powering the rx, and new battery had more power and smoked the bec in one / both esc.
