Old 02-17-2018, 07:37 PM
jack van's Avatar
jack van jack van is offline
Default Re: Rc4wd 870k wheel loader unboxing and review.
hope so
Old 02-18-2018, 10:37 AM
Originally Posted by TheBennyB View Post
When you are talking about a pressure relief valve, are you talking about the small screw on the fixture that holds the black relief tube off the fluid tank? Mine seems to either have to be tighten down or just spins pretty freely. Doesn't really seem to want to hold a position.
No, what you're describing is the air vent tube.
What I'm talking about looks like this and it is located above the left steering cylinder. You can see from underneath the machine looking up towards the cabin. https://store.rc4wd.com/Pressure-Rel...er_p_2114.html
Old 02-19-2018, 01:41 PM
Ahh yes. That's the pressure regulator not a relief valve right? On my other Eagle machines you have the pressure regulator and an actual relief valve with a needle screw that is adjusted to let pressure out if needed.
https://store.rc4wd.com/Ventilation-...nk_p_1823.html
Old 04-24-2018, 01:46 AM
New video.
https://youtu.be/Ng2dQPOM3rk
Old 04-24-2018, 11:07 PM
Cat966c Cat966c is offline
Do I have to have a pressure release valve? Is it absolutely necessary? My loader is going to run the small m3 magom pump
Old 04-24-2018, 11:28 PM
jack van's Avatar
wow yours is still working your lucky haha
Old 04-25-2018, 02:52 AM
Rimrock Rimrock is offline
Yes. Concerning the small Magom pump, the pressure release valve is placed in the same block as the pump
Soyland Industrier
Old 04-25-2018, 05:37 PM
Like a champ. Not a single issue yet. And you can see in the youtube video, how I use it. It's really moving dirt.
I also have another video on the same day which was 25min long. I purposely put the shorter one on YouTube.
Old 04-25-2018, 05:59 PM
So it’s already built in??
Old 04-25-2018, 09:10 PM
Nice vid, looks like your moving some good amounts of material! Mine is also still running great.
Old 04-25-2018, 09:12 PM
What you going on now Van?
Old 10-30-2019, 06:39 PM
jack van's Avatar
so has anybody have recomendation for cheap hydrolic oil
Old 10-31-2019, 08:13 AM
Bo Wallen's Avatar
Lightbulb Re: Rc4wd 870k wheel loader unboxing and review.
Do NOT use cheap hydraulic oil, Use high-quality oil, and keep it clean. The amount you will use does not break any bank.
