-   Construction Equipment (https://www.rctruckandconstruction.com/forumdisplay.php?f=6)
-   -   1:14 RC Tracked Conveyor (https://www.rctruckandconstruction.com/showthread.php?t=14206)
Blender 10-26-2025 09:29 PM
A couple years ago a local guy built a really nice trommel. Only issue is the feed is too tall for most machines to load on flat ground. This device will solve that. Will pull double duty as being able to deposit shredded rubber into 5 gallon buckets to clean up at the end of events. Ideally a machine that can be setup in the morning and let run unattended all day.
Based on Terex, but will be between sizes with functional differences to work in small scale. Not a true replica.
https://i.ibb.co/W40cyk3B/mobile-hopper-feeder.png
https://i.ibb.co/d0DPs7Yr/Prostack-R...-H-image-1.png
Drive belt has been the key part. Bruder's is really nice with cups for steep angles, but too small. Spliced rubber sheet looks great and is super thin, but is never true (when i build it). Megadyne T150 is perfect, but they never pointed me to a distributor in the US. Tried several custom belts from Misumi until i found the right one. Lots of width options, thin and has a woven texture for some grip. Only bummer is it's green. Built a simple fixture to test belts. Rollers are 0.75" 19mm dia aluminum on 8mm shafts. Aquarium gravel transports best at less than 20 degree incline. Granulated rubber appears to tolerate up to 27.5 deg without tumbling. Good news for a short conveyor that still has enough vertical reach. This is much steeper than the real machines
https://i.ibb.co/Y7859wfw/Progress-1.jpg
Some details
  • Tracks and drive is from Double E Volvo 160 excavator. Temped to use the gearbox too
  • Hydraulic cylinders from Magom
  • Valves are Lesu 4 spool i have on hand.
  • Pump: Scaleart tiny pump ordered to try out. Otherwise i'll get another Leimbach since they are a sure thing.
  • Hydraulic functions are: conveyor height, conveyor fold, rear feet and hopper discharge sluice gate.
  • DC gearmotors for feeder and conveyor
  • runs on 3S 5000 mah lipo to be common to my trucks. External strobe light will act as low voltage warning since transmitter won't always be connected to receive telemetry data
  • low hopper <7 in from ground to be fed with modest sized wheel loaders (MCL8), but wide enough for a full bucket from something larger (wedico Cat 966G) or excavator of any size
  • Construction will be almost entirely stainless steel sheet. Trying to minimize machined parts for simplicity
  • When folded must fit into my existing case geometry.
Already confirmed i can alter the failsafe setting of the receiver inside to hold speed of both conveyors if/when radio signal is lost. External power switch will keep things mostly safe.
https://i.ibb.co/fGT3yQxV/cad-3.png
https://i.ibb.co/dJGGghQB/cad-2.png
Still a ton to do before i can start on the physical build. Focus will be on the hopper/feeder to verify is works.
Zabco 10-27-2025 02:53 PM
Re: 1:14 RC Tracked Conveyor
Oh this will be cool. I love this type of equipment. There is a company only a few miles from where I live that makes all sorts of crushing, screening and conveyor systems. They are called Screen Machine Industries and I always like driving by their facility because they always have some neat looking equipment sitting in their yard. Their web site is screenmachine.com if you want to see what they make.
Could you glue thin strips of rubber to the belt to assist with moving the material up the conveyor?
Blender 10-28-2025 12:00 AM
Screen machine has some cool stuff. Mobile Crusher is too ambition for me, but I'd love one. Same with the mobile shredder. Too cool.
Glueing on some ribs or scoops is exactly plan B. Hope I don't need it, but I'll do what it takes. Rubber strips of all thicknesses are readily available on McMaster-Carr.
ddmckee54 10-28-2025 05:22 AM
I used to work in a food processing plant, and I've seen a lot of conveyor belts in various widths, from 50+ inches down to a couple of inches. Buying the stock for the belts ain't cheap.
Have you thought about making your own custom belts? Used treadmill belts belts can be had for a few bucks, they are usually only a couple mm thick, and they are the right color. They can be split to the desired width, and then scarf joined to length. Winky's Workshop had an excellent video on how to make a custom flat belt using heat cured glue. A 90 degree scarf joint is the easiest to make, but will be a little noisier when the joint hits a pulley/roller. An angled scarf joint will be quieter as it runs over the rollers.
Don't forget to crown the pulleys/rollers, it makes tracking the belt much easier - crowning the pulley will make the belt want to self-center. A few turns of tape in the middle of the pulley/roller should be enough, just be sure to wrap the tape in the proper direction. A small slice of heat shrink tubing might also work. A softer material with a lot of grip on the drive pulley/roller helps avoid belt slippage, and be sure to make the idler pulley/roller adjustable for belt tracking. Also, you want to pile your product up in the middle of the belt when you load it onto the belt, keep it away from the edges. The product will spread out as it travels, every time it gets jiggled around a little it'll spread out.
If you do add ribs to the belt, I'd keep them as narrow as possible, and as far apart as possible. The ribs are going to make the belt stiffer and harder to drive around the pulleys/rollers. Make your drive and driven pulleys as large as possible, idler rollers can be small, but the end pulleys/rollers need to be big.
Don
Blender 10-28-2025 10:47 PM
Great info Don.
I did experiment with building my own belt. I was never happy with it. I'm sure it's partially skill based. Also looked at gravity molding my own, but the required mold size is just too big to be practical. Instead I'm using these:
https://us.misumi-ec.com
1mm thick, width in 5mm increment and custom length in 10mm steps. Only cost $10 each for 50mm x700mm
Tracking was exactly my concern the fixture above was assembled with great care to try and get everything as square and true as possible. Just to see how much adjustment I really need. Tracked OK, but not perfect. Crowned rollers might be exactly what I need. Should be able to modify what I have to see how it acts.
ddmckee54 10-29-2025 12:03 AM
That's really not a bad price, when I was looking for U.S. suppliers the 50mm stuff was about $5/foot. You only need a couple of degrees of crown on the rollers. If you've got solid rollers, just turn a shallow taper on each end and leave a small flat section in the middle. It seems counter-intuitive, but the belt will track to the high side - that's how the crown works.
If you don't like the green color of the belt, vinyl upholstery dyes are available at a lot of auto parts locations. I've seen prices from $11, to over $30 per spray bomb. 40 some years ago I changed the headliner color on my '57 Ranch Wagon using that, worked like a charm and only took 2 cans.
Blender 11-02-2025 02:26 PM
Tried out a couple wraps of tape in the center of the roller to mimic the crown. Certainly helps tracking. Thanks Don!
Let the fixture belt run for 30 minutes unattended. Pretty fast motor at 200 rpm. Tracked well. Motor slightly warm. Solves the biggest hurdle. Now an overwhelming amount of CAD to do.
frizzen 11-07-2025 11:33 PM
That's a really cool looking machine.
Going to be really fun watching this come together and seeing how you solve the challenges
ddmckee54 12-11-2025 01:47 AM
Blender:
If you aren't too far into that overwhelming amount of CAD, you might want to check out cults3d. They've got a more than a few conveyors on there. I searched for rc construction, and got 136 pages of hits - with 48 listings per page. Santa might be good to me this year.
Don
Zabco 12-11-2025 07:12 PM
And just when I was about to give up absolutely all hope that this site might survive... Thanks Don.
Blender 12-14-2025 01:04 PM
There is a ton of stuff on cults3d. Some great some downright crappy. I am sticking to original design made from steel on this. Used them to get a super duty body I rescales to 1:14 and printed it out. Turned out well, slightly warped.
https://i.ibb.co/cSbPZ0yS/Progress-28.jpg
While we are on the subject I changed direction a little on the feeder. Swapping feeder belt to chain drive with crossbars. Saw a glimpse of this on goldrush and prefer it to avoid feeder belt slipping under a full hopper. I expect rubber, gravel or general dirt to be used. Found some really small chain .1475" pitch and will power it with a fusion mini16 with a gearhead. Searching for cheaper chain instead of $90/ft, but everything else is bigger. Easy replacements parts always appeals to me so I'll probably just go for it. No tensioner, no alignment adjuster, very simple.
https://i.ibb.co/jkWJfV0h/cad-4.png
Also got a scaleart pump to try out. Pretty small. Probably low flow. Looks like hardened steel construction so it should be pretty nice. 16 bar ~230 psi. Leaving the stock brushed motor on this since it'll rarely run. And already fits.
https://i.ibb.co/ZzVp0854/scale-art-pump.jpg
half of a Leimbach for scale
Zabco 12-14-2025 02:39 PM
Like the crew cab you're making. What kind of frame are you putting under it?
I like cults, there is a lot of interesting designs on there. If you are looking for a loader, large excavator or haul truck I highly recommend taking a look at the models designed by burnie222rc. Very well designed and for 3d printed construction equipment, they can really take a beating. I built his small cat loader and am very pleased with it.
Blender 12-14-2025 05:28 PM
Good to know the Bernie models are solid. Never gotten a chance to play with one in person.
the Ford was supposed to be based on a Traxxas trx4m. Kinda narrow so widened axles with new metal housings. Stock knuckles. Originally designed it with a copy of the Traxxas 4link on a simple steel frame. I lost those files when I upgraded my cad desktop to windows 11. A couple folders were not synced to the cloud. My mistake. Been redesigning it to use lesu leaf springs and my own radius arms in the front. Will be poor performance, but true to scale. Should look good on course with the semi trucks.
https://i.ibb.co/23fd6fxy/progress-8.jpg
https://i.ibb.co/qMh379Bd/progress-6.jpg
Zabco 12-15-2025 07:24 PM
I was curious as I have thought about doing something similar to have a 1/14 scale work truck to pull small trailers. I don't have any real experience with the crawlers so am not familiar with all their different axles and drive train components.
Look at some of his videos on youtube. He lives in Norway and his back yard where he tests his models has to be the rockiest, semi-frozen muck you've ever seen. It's amazing what his equipment can dig into and move. I only have his smaller Cat loader so far and I absolutely love it.
ddmckee54 12-15-2025 09:55 PM
Thingiverse and Cults3d both have their fair share of crap.
I agree with you both, Burnie has built some fantastic models. If you like tanks, or other tracked vehicles, then check out RC_3D_TANKS. I've got the files for a couple of his models, the M113 and the M551. I haven't BUILT them yet, but I've got the files. He models his stuff at 1/16 scale to use the Heng Long parts. I figure if nothing else I can use them as static loads once I get my trucks running, since all the Bruder stuff is 1/16.
This guy does good work too, Russian self propelled combine Damned near everything appears to function on that model, even the cutter bar on the grain head moves.
I've been told that I WILL get my garage door installed this week. Luckily my garage door faces east and I don't have a new garage full of snow - yet.
Blender 12-15-2025 11:05 PM
That combine looks killer. Very well modeled and I'm quite partial to soviet Era equipment. Kind of elegant, but kind of brute force looking. Occasionally I've been looking for older/classic 1:1 machinery to build in model scale. Nothing has really jumped out at me just yet and I have other projects to finish
Blender 12-15-2025 11:20 PM
zabco,
honestly I'm not much of a crawler guy anymore. All the 1:18 scale stuff is too small in terms of body, axle width and tire size. Bought a trx4m to try out. Took it apart after 10 minutes of playing. Will end up using maybe 6 parts total. Should have bought A-la-cart
