Old 01-03-2014, 03:20 PM
dsdmax dsdmax is offline
dsdmax is on a distinguished road
Default Re: motor and electronics for a track loader
thanks for the updates - i will read through that thread again ... ok so sounds like i will need two ESCs but i can start with one for now and see if i can get the motors turning.
Planning on 1/12 scale so that should give me about 5 inches width in the body. I have mill so will be making the 90 degree turn with bevel gears.
As for the reduction - i really would like to do a planetary gear reduction hub. that said the internal gear will be a problem. I have a rotary table so maybe i could broach one but ... I am also considering a hypocycloid ( more information here - http://www.zincland.com/hypocycloid/ )
not sure i will figure it out but would be cool.
I will get the motors and the ESC and see what i can figure out for the drive train - then model around that.
thanks
