Old 04-01-2014, 11:49 PM
avel avel is offline
Default Re: LR634 is HERE!!!!! Tracked loader
I will definitely be cleaning the surface first, it has some kind of oil on it. I have mineral spirits/rubbing alcohol etc. Good idea with the tape, I wouldn't of thought of that. Less sanding and finishing work for me.
Ok, following will be pictures of areas that I really want to hit with JB Weld for appearance and strength purposes, oh and to make clean up easier. First will be a zoomed out picture than a zoomed in picture of the particular area.
On an area like the below picture, if I wasn't sure I could keep the edge sharp I was thinking of applying the JBWeld to the inside.
Both of these cylinder attachment points need cleaning up and I want to JBWeld the little gaps for strength. I'm sure thick enough paint could make it disappear, but the JBWeld would strengthen the area. Pictures below.
Another area I want to hit.
Gaps here.
In the picture below I would like to close off the gap, except where you can see the other side. Dirt would get stuck in there.
