Re: completely off the topic.
			ATF brakes down inside of the forks to easily causing them to become unefficient. I use reg fork oil. The way I see it is that a bottle is like $10/20 and when adjusting front forks for comfort your adding or taking an ounce to half ounce at a time.. But if your re doing the seals remember to measure how much oil was in it and then start at that point with the new oil. if your front end was soft before then add a little more but be even on both sides. If not you will go thru tires faster and improper dampening will cause winds and stuff to blow you around etc... I was amazed when I re did mine a few weeks ago and added more how much of a difference it made.
