Old 11-09-2010, 05:48 PM
pumptech's Avatar
pumptech pumptech is offline
pumptech is on a distinguished road
Default Re: bruder trackloader conversion
Hey guys thanks for the comments.
Hey Sparkycuda ,Parts list for the rams.
I"ve been looking at some other ways to connect the rams to the servos,
the method that I show in the pics above (first post) seemed to work ok for a while then it started slipping a little under strain.
Come up with this method and it seems to work much better.Weld the bit to a short piece of SST tubing.
Parts needed
3/8" SST tubing with 1/4" ID (seems to work the best)
1/4" wood auger bit or masonary bit ( much cheaper)
I used # 4 drill bit ,#4 tap ,#4 set screw ( If you can find bit ,tap,set screw smaller that would work to)
Pic to follow on my ram
