Old 11-17-2010, 01:39 PM
Marcel74 Marcel74 is offline
Marcel74 is on a distinguished road
Default Scania W.A. Prime Mover 1/14.5
Hello Mini Truckers
Danke you for the Messages.
I buy a normaly Wedico Kit in 2007
After 3 Yaers construction, is this the result.
Frame is from Wedico and my self, with Osswald and Wedico Spring also tuned (original to high). The Power Train is with a 82 Watt Faulhaber Engine and a 3-Shift Gearbox from Veroma.
The Fuel tank i make with 1mm Alu, inside is a 5 pack Battery from Orion with 5100mAh on each side.
Behind is the charing socket for the Battery
Inside the Toolbox is the Electrical rearpanel from Wedico
The Fender are from Wedico and is modifed by me. The Holders i made of Brass
This is the 1. Part, next Part will follow soon
Thank's Marcel
