Originally Posted by bigford
you really cant with the stock set up
the center pivot plate is almost at the top of the rails.
I would try to remove a few springs or try to bend the leaf flatter
That is true bigford but the suspension plate is very easy to modify to lower it and if you remove spring leaves you won't be able to carry much of any weight at all.
