Old 08-17-2014, 08:38 AM
kingbob kingbob is offline
Default Re: Movie Optimus Prime build
OK, well i blew my target of having the trailer done by the end of today. Mostly because i need to dismantle the trailer to cut 5mm off the front of each of the side panels. I forgot to account for the rounded front corners so they're in the way.
Wired in the hookups between the truck and trailer. Stainless base panel with an aluminium support for the cables. I found some small 2.5mm 4 pole headphone style plugs so using them to hookup to the trailer.
Also got the rear end mostly done, just needs doors now. Though of all the things to misplace i've lost one of the plastic pieces that the 2 door bolts slot into. Put one at the top, but cant find the other one!
The reefer is done too, the pic makes it look more sparkly/glittery than it is. Just lighting.
