Thread: JBC limited NZ
Old 10-14-2014, 12:46 AM
Default Re: JBC limited NZ
thanks, takes a while to get a fleet together.
and yes pull the axels and fit shims, also make sure all the bearings are there, mine had the bearings in the axel tube missing, standard tamyia bearing will do the job.
the dump truck , if your talking about the yellow rock truck, I scratch built it from scrap metal I rescued from the rubbish bin, I think there is a post on here under MY JUNK ROCK BUILD, has a hydraulic tipper and electric steering.
need to get some small rams, or make some when time allows for the steering.
heres a quick video of a bit of axel bashing on the loader, still going strong, must be 20 plus batteries and still no problems, cant say the same for the speaker connections, must be shorting on diff lock steel cable.
will fix on next days off.
cheers andy
http://youtu.be/-XmDzvo5B7k
